Car doesn't fire
Old 08-28-2018, 11:26 AM
DirtyDan's Avatar
Car: 1992 Camaro RS
Car doesn't fire
I have a 92 RS that will spin but won't fire in less a little starting fluid is used. Then it'll start run very rough then die immediately. Any idea to a cause? Also I should mention it ran the day before then I let the battery die overnight by mistake but I wouldn't think that would have done anything.
Old 08-28-2018, 12:04 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Car doesn't fire
This is the tpi section. Do you have tpi or tbi or v6 ?
you should start by checking fuel pressure.
Old 08-28-2018, 12:17 PM
DirtyDan's Avatar
Car: 1992 Camaro RS
It's 305 tpi
Old 08-28-2018, 12:32 PM
Engine: Lb9
Transmission: M20
You also should check the fuse next to the battery. It’s for ecm power and fuel pump power.
Old 08-28-2018, 12:47 PM
DirtyDan's Avatar
Car: 1992 Camaro RS
I was looking for that eirlear do you have a picture?
Old 08-28-2018, 12:53 PM
Engine: Lb9
Transmission: M20
Google search image
iirc it’s a 20 amp fuse
Old 08-28-2018, 12:55 PM
DirtyDan's Avatar
Car: 1992 Camaro RS
Google search image
thanks I'll be sure to check it out
Mykogee
01-19-2015 01:12 PM
cretecrawler
07-22-2009 03:07 PM
AndrewSyndrm
04-27-2009 05:21 AM
babybear82lilj
02-05-2008 05:12 PM
Quick Reply: Car doesn't fire
