Please help, No Injector pulse after first start.
Car: 1987 Trans Am WS6
Engine: 305 tpi
I am at my wits end with this car. I have a 1989 Iroc with a 5.7. I bought it and the guy could only start it with starting fluid, I have been searching for 2 months trying to find out the problem. I can start the car first time np, fires right up. But after that it just cranks and cranks.
Things I have done.
new distributor
ignition control module
fuel pressure regulator
oil pressure sending unit
fuel filter
ecu
vatz bypass with chip
tps checked
collant tempature sensor
ohmed all the fuel injectors
fuel pressure checked
I used a noid light and noticed I have fuel pressure but the injectors are not pulsing. I can spray a little starting fluid in the tb and it starts right up and runs good.
I need to add the car sat for about 2 years. I am close to burning this car to the ground
https://www.youtube.com/watch?v=jpkd...ature=youtu.be
Things I have done.
new distributor
fuel filter
ecu
tps checked
.https://www.youtube.com/watch?v=jpkd...ature=youtu.be
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Please help, No Injector pulse after first start.
What do the injectors ohm out at ?
have you wiggled the wiring back next to the distributor ?
Engine: 305 tpi
It was like 16 across all of them. The wiring looked good when we replaced the distributor.
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Cold start injector issues? I dont know how they work exactly but just throwing that idea out
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
My first question almost was what is the fuel pressure with the key forward after the pump primes and does the pressure hold, however, if the injectors aren't firing, either that VATS bypass wasn't done right or you have an electrical issue. Have you checked fuses and relays et al?
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
check this wire.
https://www.thirdgen.org/forums/tech...-cranking.html
Engine: Lb9
Transmission: M20
Have you cleaned the grounds on the backside of the passengers cylinder head ?
Car: 1991 Z28 1LE
Things I have done.
new distributor
fuel filter
ecu
tps checked
You've checked or replaced everything that is associated with a no pulse condition. I'd check the grounds that Tuned Performance mentioned and then just for fun, the next time you are cranking see if the tach is bouncing or moving.
Also 89 doesn't have a 9th injector.
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
You say the car starts the first time but how long do you have to wait before you can restart the car? Can you start the car immediately turn it off and then restart it? Just trying to see if it's a heat related problem.
Engine: 305 tpi
Still have this issue ready to just burn it to the ground lol. It now doesnt start the first time just cranks, still turns on with starting fluid.
Car: 1991 Z28 1LE
There's some questions that need answering for more online diagnosing
Engine: 305 tpi
In the YouTube video on my original post you can see what the tach does, it bounces and then pegs out when started.
Car: 1991 Z28 1LE
No youtube on my work computer
there's other questions and suggestions though?
If you truly have no injector pulse then you need to figure out if you are losing 12v to the injectors, or losing the ground from the ECU driver.
GD
GD
Engine: 305 tpi
I am thinking it's the wiring from the icm or maybe the coil. Going to check the grounds tomorrow.
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
how does it run, once you get it going with starter fluid?
when you used the noid light how many of the injector positions did you check?
Engine: 305 tpi
It runs pretty good, I need to redo the timing since I tried swapping the distributor. I only checked one injector with the noid light.
raptere
May 6, 2017 09:44 AM
gta power
Aug 8, 2013 05:12 PM
