87 Tpi belt diagram and length?
Car: 1988 camaro
Engine: 5.7 Tpi
Transmission: Manual
Axle/Gears: 3.42?
I have a 1988 Camaro 5.7 Tpi that was originally a v6, the previous owner installed an 87 Tpi and I'm trying to find the length of the alternator belt. It has the v belt for the power steering and a serpentine belt with no tensioner that runs the alt water pump and ac. Question is, what length belt do I need to run just the alternator? The ac compressor is not on the car at the moment and I'm not running the smog pump. Also what size belt is it if I decide to run the ac?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1988 camaro
Engine: 5.7 Tpi
Axle/Gears: 3.42?
Re: 87 Tpi belt diagram and length?
sflthndrckn
May 15, 2019 02:10 PM
trueburton
Aug 31, 2007 08:06 PM
