Hesistation @ idle
Old Jan 8, 2002 | 08:59 PM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
Hesistation @ idle
my car seems to have hesitation from idle when i mash the throttle to the floor. the RPM's come up real slow but when shes about 2k-2500 and i hit it i get instant response. sound like i should adjust the TPS?
Old Jan 8, 2002 | 09:38 PM
Tony86TA's Avatar
Could be a possible problem with an injector ot two. Had the same problem last summer. Ended up being a couple bad wires.
Old Jan 8, 2002 | 09:39 PM
87POSGTA's Avatar
Car: 1989 Firebird
how would i test it?
Old Jan 9, 2002 | 02:20 AM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I have the same problem too. Help us please!!
Old Jan 9, 2002 | 05:04 PM
JAY87GTA's Avatar
Check your timing first. I run about 10 degrees advanced. If you only have 5 or 6 degrees it will cause the engine to bog off the line until it gets a few RPM's up.
Old Jan 9, 2002 | 09:04 PM
Tony86TA's Avatar
Ended up I had a couple of wires with worn insulation that were coming out of the plastic wire loom that runs between the valve cover and base. I saw some threads awhile back on checking them with an digital meter, however I cant remember where they were right now. Do a search, you should be able to find it.
Old Jan 9, 2002 | 11:24 PM
rezinn's Avatar
What? Stock timing is set to 6 degrees advance, and my car ran perfect that way.
When was the last time you changed the plugs?
Old Jan 10, 2002 | 12:20 AM
87POSGTA's Avatar
Car: 1989 Firebird
Plugs are brand new and gapped at .40 timing is at about 9* new cap and rotor & new plug wires also. today i adjusted the Idle & TPS. she seems to be doing much better. now i just gotta fix the headlights (one housing broken & the other keeps catching on the front clip) not bad for the 1800 i picked her up for.
Oh yea. parting out an 87 GTA anyone lookin for any parts e-mail me NjPoGoPuNk@cs.com i got a 700-R4 freshly rebuilt with about 75 miles on it (motor went after rebuild) have receipts. Looking to unload everyting real cheap cause my father is givin me crap about having 2 GTA's
Old Jan 10, 2002 | 05:51 PM
JAY87GTA's Avatar
I've seen it on alot of cars, not just mine, new plugs, old plugs, cheap or expensive plugs. Every motor is different, like a personality ya know. Just throwing out ideas for him to check cuz he didn't say what everything was set at.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
