Over-torqued Knock Sensor require replacement?
Old Apr 3, 2019 | 03:42 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
I unknowingly over-torqued the new knock sensor and I'm getting quite a bit of unexpected knock retard. Is is "ruined" or can I remove and re-torque or maybe do a wrap or two of teflon tape?
Old Apr 3, 2019 | 08:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Over-torqued Knock Sensor require replacement?
What you said. Remove, add a layer of Teflon tape and install with 11 - 14 ft/lbs of torque. Then good to go.
RBob.
Old Apr 3, 2019 | 09:34 PM
rt66er's Avatar
Engine: L31 350 TPI
Thanks!
IH8Fords
Sep 9, 2024 05:39 PM
roughskinjrz
Dec 18, 2005 10:49 PM
Conrab
May 18, 2004 10:37 PM
Paul Riccioli Jr
Nov 16, 2000 06:21 AM
