Newb issue
Old May 8, 2019 | 05:49 PM
Papa Joe's Avatar
Newb issue
I’ve been reading about everyone’s MAF issues. So, I’ve been delaying doing any kind of cold air intake. But I was looking at my car, and there isn’t anything on the intake tube (from the filter to the intake) I can’t find any kind of sensors. I completely removed the entire assembly, and there is nothing there. What does that mean? Has it been removed? Thanks for any info.
Old May 8, 2019 | 05:51 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: Newb issue
What year is your car? 90-92 had MAP systems that do not use a MAF....
Old May 8, 2019 | 05:53 PM
427seven's Avatar
Re: Newb issue
See it here.....
Old May 8, 2019 | 05:55 PM
427seven's Avatar
Re: Newb issue
What kind of a cold air system are you thinking about?
Old May 8, 2019 | 06:39 PM
Papa Joe's Avatar
Re: Newb issue
Not sure yet. Just something with an open filter, and lighter/better looking than that stock unit. And the car is a 1992. Thanks for the info. So, would I need to worry about anything if u put a cold air intake on there?
Old May 8, 2019 | 06:47 PM
427seven's Avatar
Re: Newb issue
No, the Manifold Air Pressure sensor will tell the computer to add a bit more fuel, and as long a s you 've not made any other changes, you will probably not notice by the seat of your pants, but if you measure your performance, you should see a slight increase in power if it's a good system. The big change in adding a cold air system will be seen if you make other changes like exhaust and other breathing aids, but if you do that, you will need to re-program the computer.
Old May 8, 2019 | 07:18 PM
Papa Joe's Avatar
Re: Newb issue
Thank you
Tbird
Mar 13, 2003 06:51 AM
mhaskell
Dec 18, 2002 01:08 AM
Adidas3k
Nov 8, 2002 11:45 AM
Baron
Car Audio
Oct 16, 2002 04:00 AM
uidzer0_z28
Jul 30, 2002 12:45 PM
