Low voltage at FP Relay?
Old May 26, 2019 | 08:11 AM
BaggedMerc's Avatar
Hey Guys,
I'm running a TPI in my Mercury Pickup with a Larry's Electric computer/harness. Right now, my Fuel Pump will not fire.
- If the pump is jumped to battery it works - good
- If I jump the grn/wht line to power - pump fires
- Power and Ground to the relay appear good
- When key is on "ACC" I only see 3.3V on grn/wht
Is the ECU shot? Could it be something else? Attached a diagram for reference
Old May 27, 2019 | 07:08 PM
Vader's Avatar
Re: Low voltage at FP Relay?
Possibilities are:
Poor / resistive connection at relay;
Weak / resistive relay contact;
Mechanical damage to relay arnature;
Wire harness/splice problem in relay circuit.
Old May 27, 2019 | 10:01 PM
BaggedMerc's Avatar
Originally Posted by Vader
Possibilities are:
I'm going to see if I can measure right at the ECU to see what voltage is coming out. Relay is new, I've tried a couple with no resolution.
I should mention, the Fuel Pump power wire rubbed and grounded out to chassis, which started all this.
Old May 28, 2019 | 06:00 AM
Vader's Avatar
Originally Posted by BaggedMerc
...I should mention, the Fuel Pump power wire rubbed and grounded out to chassis, which started all this.
Yes, that could be a critical bit of information. I presume you are measuring the voltage on the GRN/WHT wire during the 2 second interval when the ignition is first turned on, correct?
Old May 28, 2019 | 07:02 AM
BaggedMerc's Avatar
Correct on the wire. Measuring on ACC when the pump primes (normally)
Old May 29, 2019 | 02:37 PM
BaggedMerc's Avatar
Just measured the voltage coming out of the ECU and it's low.
Old May 29, 2019 | 02:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I didn’t see on your post the ecm service number.
but if your looking for a 730 ecm look at these links
https://www.thirdgen.org/forums/engi...92-sd-tpi.html
https://www.summitracing.com/parts/aaz-77-7730/
Old May 29, 2019 | 03:09 PM
BaggedMerc's Avatar
It's a 730...thanks for the links, I just bought one off eBay. Had no idea Summit would sell a reman. Requested a refund on eBay, so we shall see.
Sounds like the ECU to you as well?
ULTM8Z
Jul 5, 2018 01:34 PM
IROC212
Oct 13, 2000 07:47 PM
