Good cam for a stock 305 TPI I KNOW, I KNOW, JUST READ IT.
Old Sep 30, 2019 | 08:19 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Being my car is 1 of 86 and in very good condition I do not want to do much at all to it. Especially not visible stuff but I would like to liven it up a bit. I'm thinking two ways to do that are cam and gears. Not going for big numbers, just a little more fun to drive and virtually invisible.
What cams would you recommend for a completely stock 305 TPI. In the future I may upgrade to SLP runners if I stumble across a set at the right price, Cat-back will probably get done, most likely a NO on headers as I don't want it to obviously modded.
Just something to get the most out of it. Tried searching but came up with nothing.
Old Sep 30, 2019 | 08:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Good cam for a stock 305 TPI I KNOW, I KNOW, JUST READ IT.
I’m not sure there is much to gain without some induction work. We did a cam only type deal stock rebuild L98 with headers and exhaust and it only did 226 whp which maybe is 10-20 more than some stock dyno numbers i’ve seen
it was a comp cam somewhere around 212/218 i think, i never saw the cam card.
That would be a 08-412-8 for a 110 lsa
08-501-8 for a 112 lsa
both would require some chip tuning
might do something like that or if you had more intake work, maybe next size up 218/224 or hot cam
Old Sep 30, 2019 | 09:26 AM
86FyrBrd's Avatar
I'd be happy with a 20whp jump. Like I said, I am not trying to win a race. I just want it more fun to drive and maintaining almost all originality at least in appearance.
Old Sep 30, 2019 | 09:54 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Your ‘92 LB9 already has the L98 cam. But it also has the L03 exhaust. I’d leave the cam alone and just concentrate on the exhaust from the manifolds back. There are at least 25 horses corked up in your exhaust. You also have a 2.73 gear. Some pep could be added by changing gears.
Old Sep 30, 2019 | 01:45 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
I agree, you will get more out of a set of long tubes, open exhaust, and a 3.42 rear that you will with any cam. If you want a bit more from your cam/valve train, do a set of 1.6RR.
Old Sep 30, 2019 | 02:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I should rephrase.... you can run a big cam like a superstocker does and make upwards of 280-290 whp on all stock stuff but it wont be fun to drive and wont live long with street miles lol. Those cam lobes would be very harsh
Old Sep 30, 2019 | 05:00 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
GM94666492 cam
Y-Pipe
3:42 gears
Custom tune
I think your 92 may have the smaller outlet exhaust manifolds. Going to the 2-1/4" outlet from earlier years might be a good mod also.
Old Sep 30, 2019 | 07:57 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
I should also note that you can get quite a bit SOTP pop from a better torque converter.
Old Sep 30, 2019 | 11:20 PM
ray jr's Avatar
just curious why you say he has the l98 cam .. he has a auto and thought they came with the peanut cam ..
Old Sep 30, 2019 | 11:31 PM
chazman's Avatar
Axle/Gears: BW 3.45
All the '90-'92 LB9s had the L98 cam. But the non G92/N10 ones were restricted with the L03 exhaust, including the 2" exhaust manifolds.
Old Sep 30, 2019 | 11:36 PM
ray jr's Avatar
from what ive seen id have to disagree with that .. the only ones ive seen with the l98 cam are the g92 5 speed 305s ..
Old Sep 30, 2019 | 11:57 PM
chazman's Avatar
Axle/Gears: BW 3.45
I've quoted this post about a dozen times over the years. I consider it the definitive post on factory 3rd gen exhaust. The non HO '90-'92 LB9s lost their 2.25" exhaust manifolds and 2.75" I-pipe, for the L03 2" exhaust manifolds and 2.25" I-pipe, yet still retained the same approximate power because of the L98 cam.
Originally Posted by TransamGTA350
There were only 2 different manifolds for the V8's throughout the years, but they were different depending on what motor and gearing package they came on. Here is the breakdown.
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
The manifolds from the single 3" cat and the dual 2.25" cats are interchangeable. On the passenger side manifold, some will have the heat riser butterfly valve, some will have a spacer, and some will just have a donut gasket. You most likely have the wrong manifold for your application. If you have the larger manifolds, then it may be worth it to get the larger y-pipe for some more performance.
Old Oct 1, 2019 | 12:06 AM
ray jr's Avatar
all the tech data ive seen shows they have the peanut cam .. click on the tech data above and you will see
click on 85 camaro and they will show all the cams
Old Oct 1, 2019 | 12:15 AM
chazman's Avatar
Axle/Gears: BW 3.45
Yeah, I see that. But the tech data is wrong. Think about what an LB9 power rating would be with a peanut cam AND L03 exhaust. It wouldn't be 205 HP.
Old Oct 1, 2019 | 12:21 AM
ray jr's Avatar
ok so answer me this .. what tach got the peanut cam and what tach got the good cam ? redline ?
5000 redline for peanut cam and 5500 redline for l98 cam
Old Oct 1, 2019 | 12:51 AM
chazman's Avatar
Axle/Gears: BW 3.45
Yeah, but that was all before '90. My '92 LB9 had a 5000 redline tach.
The restriction before '90 was the peanut cam. After that it was the "peanut" exhaust.
Maybe think about it this way, how did the single cat '90-'92 LB9 go to the more restrictive exhaust, and yet gain 10 hp from the previous year peanut cam LB9?
Old Oct 1, 2019 | 01:07 AM
ray jr's Avatar
so all 305 auto and non g92 5 speed cars have the 5000 redline tach and all 350 and g92 305 cars got the 5500 redline tach because of the exhaust .. not buying it .. and everywhere i look it says you had to specify g92 to get the better cam and ive seen nothing about the exhaust except the n10 option ...
Old Oct 1, 2019 | 01:38 AM
chazman's Avatar
Axle/Gears: BW 3.45
Lots of specs here:
https://www.gmheritagecenter.com/doc...let-Camaro.pdf
Here's screen shots the exhaust stuff.
We can continue tomorrow. Time to hit the sack.
Old Oct 1, 2019 | 06:38 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I wish I still had my 91 z28 305 non g92 to settle this debate lol i never checked the cam or valve lift but do know it had the tiny exhaust which was perfect for a rear turbo. 9 psi made it into a bolt on ls1 in power lol. Idk if a peanut cam car would have gained that much but who knows
Old Oct 1, 2019 | 06:57 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Thanks for not arguing with me Ray, but you got another chance now in this thread!
Chaz you make a great point on the HP numbers, By the specs in the link below it is 15hp difference from 87'. Are you sure the standard axle 305 TPI had the better exhaust in 89' and below? Something had to change to reflect this HP gain. If you look at the lift of the cam, the 88-89 peanut got the same grind as the 90-92 peanut. Maybe as a cost cutter GM just used 1 grind for all and did not reflect the tech sheets? In the link below this guy does state the standard axle 305 tpi got the peanut cam all the way through model yrs, he also specs that RPM reline on the tach as the determining factor.
http://gmtips.com/3rd-degree/dox/tips/cams/cams.htm
Old Oct 1, 2019 | 07:36 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
All speed density 90-92 305-350 TPI cars shared the same cam. A touch weaker than the 89 cam.
Old Oct 1, 2019 | 08:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Not that it matters cuz its still a puny cam
Old Oct 1, 2019 | 09:02 AM
chazman's Avatar
Axle/Gears: BW 3.45
Only the L03 got the peanut cam in '90-'92, so some of that data is incorrect.
Old Oct 1, 2019 | 09:03 AM
chazman's Avatar
Axle/Gears: BW 3.45
True.
Old Oct 1, 2019 | 09:35 AM
86FyrBrd's Avatar
GM94666492 cam
Y-Pipe
3:42 gears
Custom tune
This is something along the lines of what I am looking to do. Also considering porting/polishing factory heads and intake along with SLP Siamese runners
Old Oct 1, 2019 | 10:33 AM
ray jr's Avatar
where did you find this info ? id like to see it ..can you tell me why they have different tachs in the 91-92 z28s ? one with 5000 redline and one with 5500 redline
Old Oct 1, 2019 | 11:51 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Gm parts 10111773 is the number for the 90-92 L98 cam and says all 90-92 f body and 90-91 corvette
https://www.gmpartsdirect.com/oem-pa...shaft-10111773
Old Oct 2, 2019 | 11:10 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
You might be able to find one used on corvetteforum.
What's the limits of the heads and stuff on the 305, same as the 350? If so the GM cam in my signature works fine on stock heads, but I would suggest slightly beefier springs (~300-350lb). It's a little beefier than the stock L98 cam (higher lift, same duration but shorter LSA (112) so idle is a tad more noticible)
Old Oct 2, 2019 | 06:07 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Just FYI Az speed & Marine still makes large tube runners about $515 shipped
Old Oct 7, 2019 | 09:11 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
chevymec
Oct 2, 2019 07:38 PM
mikobu3
Jun 24, 2003 04:09 PM
Purple Monkey
Aug 6, 2002 05:34 PM
SMOKEN
Jul 3, 2002 06:16 PM
SMOKEN
Apr 16, 2002 10:47 AM
