Injector fuses
Car: 88 Camaro Iroc Z
Engine: 5.7 tpi
Injector fuses
Should the inj1 and inj2 fuses have 12v on both side of the fuses when the key is turned forward (not cranking)? Both of mine show 0v on the right side. I have an 88 iroc 5.7 tpi. Thanks
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Injector fuses
According to the schematic in the FSM, the fuses should only have 12 volts when the key is in the start position.
Here (http://www.austinthirdgen.org/index.php?pid=19), the fuses should have 12 volts in run and start positions, which makes more sense to me.
What problem(s) are you trying to troubleshoot?
Engine: 5.7 tpi
Re: Injector fuses
Car: check
Engine: check
Transmission: check
Re: Injector fuses
Depends if this is with the fuses installed or removed. If the fuses are installed they should be hot on both sides. If not then the fuse(s) is bad.
If the fuses have been removed then they will be hot only on the IGN+ feed side. The side that goes to the injectors will be near 0 volts.
Note that the ECM provides a ground to the injectors to open them.
RBob.
RBob.
Engine: 5.7 tpi
Re: Injector fuses
The fuses do have power on both sides when installed. When I turn the key, the motor turns over and sputters for a couple seconds. I’m assuming this is just the fuel igniting that may have dropped out of the injectors. While I turn the key, the metal rod that enters the top of the ignition switch does not move. If I depress the sleeve that the rod enters, it does spring back and forth
Cole Curtis
Jun 14, 2017 07:16 PM
cta1991
Aug 27, 2011 09:39 AM
