1992 pontiac trans am tpi issues
Car: 1980 Z28/1991 Z28
Engine: 305 / 350
Transmission: 5spd std/ th350
Axle/Gears: 3.42/ 3.42
i have a 92 ta with the 5.0l v8 tpi
number 3 injector seems to be flooding the cyl with fuel
ive replaced everything ecm, prom, injectors, dist, coil and module, egr valve, map, tps,iac
but still have number 3 flooding
im sure it has to be wiring but why only number3
if you have any ideas pleas let me know
Transmission: Pro-built 700R4
Engine: 305 / 350
Re: 1992 pontiac trans am tpi issues
yes you did
but it was no help and off topic
would you have any actual information that would be helpfull
or are you just on here to be a smart ***?
Dude, I was just messing around, but since you want to be a jackass, GFY.
Car: 1991 Formula
Transmission: 5-speed
Hello there, there is an article about excessive fuel in cylinders for 5.7 TPI in justanswer (website), which seems to point to a timing issue. It's a long article, you may want to check it out. Perhaps it helps.
Engine: 305 / 350
The injector wiring can't do this - it would have to flood all cylinders on the same bank. The wiring has +12v to the injectors at all times, and they are wired 1/3/5/7 to one injector driver, and 2/4/6/8 to the other driver. So if it were wiring, all the injectors on the odd bank would also be flooding their cylinders...... unless....
There could be something really special going on where there's an open in the control ground from that specific injector and the injector side of the open circuit has grounded out on the engine somewhere leading to that injector being open all the time.
Unplug all the injectors and the ECM and ensure that the ground side wiring of each injector is open (infinite resistance) on your meter.
GD
GD
Engine: 305 / 350
any idea where to get the right wiring diagram at
Engine: 305 / 350
so if im reading this right
all 4 injectors 1357 are connected back to the ecm on one wire ?
467 dk blu to bc11 on the ecm connector
so theres only one wrie to check on that side
and thanks for the info
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Correct. May want to look at the splice where the wires from the injectors come together. If there is a wiring issue, that would be the first place I would check.
Engine: 305 / 350
thanks for the help everyone
working great
running smooth
working great
running smooth
Engine: 305 / 350
a bad brand new injector
and a broke injector wire i caused
and if i read it right i should be using 19 to 21 lbs injectors in my 5.0??
19lb for stock 305 programming.
GD
GD
Engine: 305 / 350
do ya know whear to get a good set as cheap as possible
i just put a new set in jan but have had one already fail
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You get what you pay for, cheap is not the answe for injectors.
contact southbay08
contact southbay08
Car: 88GTA
Engine: 5.7TPI
https://www.southbayfuelinjectors.com/
They are on here. Mention 3rdgen and get a discount. Around $160 Bosch III's. Or just get some other ones.
Southbay Bosch III injectors require tuning (in my opinion, and I'm not the only one). They have no published voltage offsets which complicates the tuning process. You can get Delphi's that are direct replacements but they aren't nearly as cheap. As with many thing you do get what you pay for.
GD
GD
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
GD
GD
