Anyone put together a list of CARB approved cams for L98's?
Old Dec 14, 2019 | 10:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If so post up please.
Thinking of the CompCam 262HR-12, but wondering, other than Crane, what's out there.
Old Dec 18, 2019 | 09:51 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Anyone put together a list of CARB approved cams for L98's?
I do not have a list of CARB approved cams, but I know of only two companies. Crane and Comp Cams. Crane has the old 2032 cam which I believe is carb approved. Comp has about 4 cams that are carb approved. I have one in my 87 Monte Carlo TPI swap. I think the Comp CARB approved cams are under their "computer compatible" list of cams.
Good Luck.
Old Dec 19, 2019 | 12:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
We've passed CA's smog test with 226/232 camshafts. Just don't tell them what's in it.
The camshaft goes with the rest of the combo, so what are you planning?
Old Dec 19, 2019 | 01:29 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
No smog tech is pulling cams to see EO numbers, nor will they have any way to know it's cammed. If the visible parts are EOd and your numbers pass, you're good.
injdinjn
Southern California Area
18
Feb 1, 2011 06:35 PM
gurkgurkgurk
Carburetors
Apr 7, 2009 08:20 PM
emilio
Mar 27, 2008 09:03 PM
loomdog32
Mar 7, 2002 06:27 PM
86TpiTransAm
Carburetors
Feb 22, 2001 12:33 PM
