TPI questions
Old Jan 13, 2002 | 06:08 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
TPI questions
ok once again guys, i'm looking for a tpi setup, was considering a MAF setup, how do you think this setup sounds?
305 H.O. roller, bored .20 over
Crane Powermax 2032 cam 214/220 duration .452/.465 lift
World Product S/R Torquer Heads
Headman Shorty Headers
Gutted Cat
Edelbrock 3" Cat back
No Emissions
T5 with 2.95 1st gear
3.73 Posi Rear
TPI Setup
Stock Base
Arizona Speed And Marine 52mm Throttle Body
Arizona Speed And Marine Large Tube Runners
AFPR
Jet Air Foil
19/lb injectors
all hooked up to an accel DFI Computer
anyone see any problems, or what i might see in the 1/4 mile with this setup?
thanx
Old Jan 13, 2002 | 07:19 PM
vortech305's Avatar
i dont see any problems so far, we sort of have the same setup, what ur gonna hear from most of the guys is the "Bigger is better' or "Theres no replacement for Displacement" theory while some of it is true, nothing wrong with ur setup, go ahead and built that setup and show a couple of 350 owners what a 305 can do.
Old Jan 13, 2002 | 07:28 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'd go with a 350 .030 over, and consider a forged 400 crank while you have it apart.. wish I did.
-- Joe
Old Jan 13, 2002 | 07:58 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
the motor is not apart it was just rebuilt and theres a computer controlled q-jet on top and it hauls a$$, but i like the way tpi looks and the start up and go effect i dont want a 350.
Old Jan 15, 2002 | 12:52 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
383! THERE IS NO OTHER WAY!!!!!!!!!!!!!
Old Jan 15, 2002 | 04:14 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
i didnt ask what cubes i should go with i asked about TPI, what is it with you guys and the 350's and 383's, i have a perfectly fine 305 that i want to put TPI on that's all....
Old Jan 16, 2002 | 01:30 AM
360Iroc's Avatar
383 tru that. been there done that
Old Jan 16, 2002 | 02:15 AM
Earl 87gta's Avatar
Let me know if you need any part I have some extra stuff laying around ECM z28 air box TB 22lb injectors think I even have a mass have a harness but rilly dont want to have to take it out of car but may if the money is write,
Old Jan 16, 2002 | 07:40 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
how much do you want for the ECM and i could use the harness also? how much do you want for both?
Old Jan 17, 2002 | 12:06 AM
Earl 87gta's Avatar
Ill go look at it tomarrow the car was coverted over to TPI from TBI so mabe it will not be hard to remove If I can get it off the car easy then Ill let you know.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
