Need help with PCV on passenger side
Old Mar 26, 2020 | 10:22 PM
L-ninety great's Avatar
Hi, over the past week I’ve done a lot to my TPI. New radiator, cooling hoses, belt, t stat and the project that gave me the most trouble was the valve cover gaskets. The drivers side required the removal or re-placement of a few little things, but all things considered was way easier than the passenger side. Anyway, I’m having trouble with the valve on the passenger side. The little black plastic tube broke, the hose that connects it to the intake is worn from old age as well. How vital are these to running my engine? I notice by putting my thumb over the disintegrating rubber piece connected to the intake, it’s sucking air to the intake. I figure the drivers side component is to bring in air and all of the crankcase fumes are then sucked through the black tube, through the rubber tube, to the intake, then burned. My main questions are; how vital is this, and how do I find a new replacement? Thanks sorry for any confusion.
Old Mar 27, 2020 | 04:58 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Need help with PCV on passenger side
There's no valve on the passenger side valve cover on TPI engines. It is usually on the driver's side valve cover.
This plastic tube?
The plastic tube comes with the new PCV valve. The hose and plumbing is another matter. The grommets for the valve cover are available. Proper sized PCV hoses are available in bulk but they won't have the custom bends in it.
How vital is this system? http://www.agcoauto.com/content/news/p2_articleid/197 I wouldn't pretend it isn't needed. At best, it'll be just a huge vacuum leak.
Old Mar 27, 2020 | 09:27 AM
[QUOTE=paulo57509;6361462]There's no valve on the passenger side valve cover on TPI engines. It is usually on the driver's side valve cover.
This plastic tube?
It’s sorta like that, but it’s just a rubberized tube that connects to a long plastic tube(black part that’s broken) then ties into the intake through a disintegrated rubber hose. It’s not that, sorry for confusion.
ossseo28
Nov 12, 2007 06:00 PM
firebirdjosh
Jun 19, 2005 12:23 PM
MTPFI-MAF
Aug 10, 2004 12:38 AM
Mathius
Jun 7, 2003 03:32 PM
