Mini-ram question
Old Jan 15, 2002 | 10:31 AM
Torqomeo's Avatar
Mini-ram question
Would a min-ram flow enough air for my 400 small block?? Or port and polished one?? I'm moving my plans forward cause my buddy just bought a '87 Grand National and i can't lose to him. And i don't want to use a carb.
Old Jan 15, 2002 | 10:51 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
i dont really know specs on it or anything but depending on how wild ur engine is you should be ok, assuming its not like 600hp or anything.
Old Jan 15, 2002 | 01:47 PM
Torqomeo's Avatar
Hoping to be in the 400HP range or close to it. Do anyone know if you can find these things used or not??
Old Jan 15, 2002 | 02:45 PM
rhuarc30's Avatar
You see 'em for sale used occasionally, but not very often. You could try the LT1 or LT4 intake conversion like Millican
Old Jan 15, 2002 | 03:12 PM
Gta-Paladin's Avatar
I think Jester is running a 400 with a miniram on it.. There are people doing it so it must work.. If you want to Make HUGE numbers turn a carb over to fi.
If you want to run like 600 hp holley and edelbrock offer som similar products
Old Jan 15, 2002 | 03:16 PM
Bad 91z's Avatar
The mini-ram would do just fine. Ive seen them on 720 horse motors before. However theyre extremley expensive,I just sent an LT-1 intake to John Millican to have him fab it for me. Im hopin' to make 750 on the bottle.
Marty
Old Jan 15, 2002 | 03:23 PM
StocRoc's Avatar
How much does John charge to modify the LT1 intake?? Also what do you do about your computer chip?? Does it have to be reprogrammed??
Old Jan 15, 2002 | 03:29 PM
Bad 91z's Avatar
He charged me $200 to mod the intake, and for another $80 he'll supply the necessary custom fuel lines.You dont have to reprogram, but it would be a good idea to. Im using DFI.
Later
Marty
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
