Everyone make sure you have correct injectors if you have an idle/stall/mixture issue
Old Sep 17, 2020 | 12:17 PM
Dirty_Duke's Avatar
Car: 91 firebird formula ws6
Engine: TPI 305 (R6P)
Transmission: R6P t5 5 speed
Axle/Gears: 3.42:1 Posi Diff
I've been chasing a idle/stall/mixture issue for about 3 months on my 91 305 tpi and I finally found the solution. Oxygen sensors where reading rich but fuel pressure was low. Asked PO about injectors and he said it had 24lb injectors. Stock is 19lbs. Big difference when you have no other mods. So I'd you where having a similar issue, make sure you have correct injectors/stock parts. Big thanks to everyone on this forum that helped me!
Old Sep 17, 2020 | 06:30 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Re: Everyone make sure you have correct injectors if you have an idle/stall/mixture i
More than just size, if you change injectors, Voltage offsets and other tuning may be needed. Also, when looking at flow ratings, the pressure the rating is at is important.
Old Nov 4, 2020 | 04:15 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I just got a new laptop so i really need to look into this..and its FREE!!!>>!> NICe!!!!
http://tunerpro.net/
Old Nov 12, 2020 | 11:53 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Well, good news is there is no vacuum leak. Used a smoke machine and there are no leaks at al thank goodness.
musicfreako
Feb 20, 2012 12:03 PM
X-Ravin
Sep 9, 2010 05:37 PM
Grizzlee
Jul 28, 2010 05:22 AM
92 Rag
May 10, 2005 01:36 AM
Casey_Butt
Aug 16, 2004 01:42 PM
