Occasional high idle with adjustable fuel pressure regulator.
Old Oct 11, 2020 | 02:28 AM
Dirty_Duke's Avatar
Car: 91 firebird formula ws6
Engine: TPI 305 (R6P)
Transmission: R6P t5 5 speed
Axle/Gears: 3.42:1 Posi Diff
I just got the correct injectors in my 91 305 TPI 100% stock now 19lbs and it seems to run flawlessly now. It used to have a high idle and pulse but now it's perfect. But sometimes after some driving my rpms will go up to around 1100 or so and stay there. No pulsing or bouncing. Is that just my fans coming on and the alternator producing a load? What should my rpms do under a load like that? How high? I have an adjustable fuel pressure regulator that seems like it's perfect where it is but hasn't been adjusted since all fp gauges I tried leak really bad. Also don't know if minimum idle needs to be reset since it was set when it had 24 lb injectors. Also: don't know if it's normal for the rpms to gradually come down from 1k after stopping at a stop sign with the clutch in, comes down in about 5 seconds. Thanks for any answers!
Dirty_Duke
Sep 14, 2020 11:42 AM
Cdeez
Jan 10, 2019 09:25 PM
happyhapka
Jun 26, 2015 03:37 PM
xrcrx
Sep 6, 2007 04:46 PM
BlazinOR
Dec 18, 2001 04:20 PM
