VAFPR and dialing in high pressure spring
Old Jan 6, 2019 | 02:04 PM
Cdeez's Avatar
Car: Too many to list...
I read lots of mixed opinions on whether or not a VAFPR is a worthwhile setup on a TBI using a 7427 PCM. I currently have a 27 PSI spring in my regulator, hoping to fuel a SBC that I estimate should make about 400 FWHP.
So, should I be using a VAFPR to lower pressure at idle? Or can this be tuned around without using a VAFPR?
Old Jan 6, 2019 | 03:04 PM
morgsie's Avatar
Re: VAFPR and dialing in high pressure spring
After about 18 psi you want to go to a VAFPR. The problem with high pressure @ idle is overfueling.
Old Jan 6, 2019 | 04:38 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I did not overfuel at idle at 30 psi running 61# high pressure marine injectors. I was at 1.1-1.2 msec at idle. I have also taken a lesson from 2.8s and 4.3s and 454s and run completely asynch calibrations to stretch the injectors further at both idle and WOT.
Old Jan 6, 2019 | 05:02 PM
Cdeez's Avatar
Fast, so you were running 30 psi WITHOUT a VAFPR??
Will you please elaborate on what parameters you had to tweak to get idle not to be crazy rich?
Old Jan 6, 2019 | 06:30 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
And can you explain this as well?
Old Jan 9, 2019 | 11:28 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I ran 30 psi without a VAFPR. Pulse width was about 1.1-1.2 msec at idle on my setup. Biggest change I made was use the injector correction data from a 1995 454 that used the high pressure fuel system to start with. Even though those 454s used the smaller high pressure 4.3 injectors it is still a closer starting point than the low pressure stuff.
Old Jan 9, 2019 | 11:35 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The 2.8/4.3 and later 454s often have asynchronous injection only. Asynch fires the injectors at a fixed rate rather than in synch with the distributor reference pulses. This gives you more control over them at both low pulsewidths and allows you to run a longer pulsewidth at higher PRM. Asynch fires at a fixed 80 hz or once every 12.5 msec.
Old Jan 10, 2019 | 09:25 PM
Cdeez's Avatar
Would that be either of these two binaries? BMHK BHDF are both 7427 454 $0E codemask... Would these be the later model TBI 454 binaries you speak of that used high pressure injectors? The injector data you're talking about is "Injector Offset VS Battery Voltage" and "BPW Multiplier VS Fuel Pump Voltage" ???
Makes me wonder why did they not set them all up to run asynch to begin with if it gives more control over the injectors??
Video
Mar 13, 2015 10:56 AM
mclarenryder
Jan 16, 2008 09:11 AM
evilminds
Jul 26, 2006 03:26 PM
super83Z
Carburetors
20
Jul 12, 2001 02:46 PM
GlennS87
Apr 7, 2001 04:42 AM
