Worth TPIS Bigmouth and runners if Procharged?
Old Feb 19, 2021 | 02:15 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I have a Bigmouth intake, Lingenfelter TB (58mm) and Accell larger runners to fit. My 305 is Procharged. It runs great at the moment with 10psi of boost.
My question is: Will I notice much difference doing the upgrade or does running a blower overcome the shortfalls of the tpi system anyway.
I'd love to know. Thoughts?
Old Feb 19, 2021 | 09:21 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Worth TPIS Bigmouth and runners if Procharged?
Yes, there will be a performance gain.
Old Feb 19, 2021 | 10:02 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Ok then. We are good to go! Thanks, I wasn't sure if it would be worth the hassle
Old Feb 19, 2021 | 10:15 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yeah it will increase power, may even drop boost some. The larger runner system will help peak power push up alittle higher in the rpm range. Maybe 100-200 more rpm and thats gonna be more power every time
Old Feb 19, 2021 | 10:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Boost multiplies gains. If something gives 10 hp gain naturally aspirated, then you'll get even more with boost. Spending money on the little stuff pays off even bigger with boost.
25th92RS
Aug 12, 2010 01:05 AM
racing geek
May 28, 2008 12:23 PM
yaj15
Oct 3, 2007 09:44 AM
Larry Dunlap
Jan 21, 2003 03:38 PM
88redxtsy
Sep 14, 2002 01:44 AM
