Help Fining Engine /Evap Part
Old Apr 12, 2021 | 11:24 AM
CobraKai's Avatar
The thinner hose is the one the cracked and broke off. i was wondering if anyone knows what part/ part number that is in the picture?
Old Apr 12, 2021 | 11:42 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Help Fining Engine /Evap Part
EGR solenoid, oem replacements are no longer made IIRC but check maybe Classic Industries. You can use C4 Corvette ones which are not cheap or I believe mid 90's Cadillac ones if you want to replace the pig tail as well. If you do a search for EGR solenoids there are a few good write ups on it. If just the hose cracked/broke you can join the 2 broken pieces together with the correct size vacuum hose, will be a whole lot less money.
Old Apr 12, 2021 | 12:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
DORMAN 47418 Tubing Dia.: 5/32"
Broone115
Nov 9, 2011 06:52 PM
89RSRedConv
Jun 25, 2010 09:26 AM
astroglyph21
Apr 22, 2010 08:37 AM
Crusin' 1980's
Mar 31, 2006 01:33 AM
thirdgenhero
Nov 26, 2004 05:13 PM
