Stripped security torx on FPR
Old Jun 10, 2021 | 07:26 AM
ksattic's Avatar
Car: 1987 T/A GTA
Engine: 5.7 TPI
Hi all, I'm new here - just got an 87 GTA with 35k original miles on it. The car is in great condition all over but has an issue where it loses power when accelerating around 3200 rpm and I have to then let my foot off to let it shift.
Plan was to change fuel filter, FPR diaphragm, then do fuel pressure test and potentially replace fuel pump.
However, one security torx screw on the FPR looks like is has been damaged - all others OK. I didn't expect that anyone would have been in there. On closer inspection, it looks like someone tried to repair a gasket leak on the intake manifold so perhaps they have. Very little space to work in there. Any ideas?
If I end up removing the fuel rail and FPR entirely, what should I replace while I am in there?
Old Jun 10, 2021 | 08:16 AM
Whitebird75's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 L V6
Re: Stripped security torx on FPR
With the relatively low millage on your car, I would also go ahead and replace the injectors, as sitting for long periods of time tend to gum up the injectors. SouthBay Fuel Injectors (a Forum Sponsor) is generally to go-to place for fuel injectors. Also, members here get a discount.
Old Jun 10, 2021 | 08:48 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Rebuild the crossover o-rings sk24 standard motor products. Still enough of a head to use vice grips to remover the tamper heads. You can replace with Allen heads . Microfasteners has them
Old Jun 10, 2021 | 09:00 AM
Engine: Lb9
Transmission: M20
https://www.microfasteners.com/scm35...ric-alloy.html
Old Jun 10, 2021 | 09:58 AM
ksattic's Avatar
Car: 1987 T/A GTA
Engine: 5.7 TPI
Thank you all for the tips, I will order the fasteners, injectors and gaskets - think I already have all the O-rings.
Old Jun 10, 2021 | 10:01 AM
Engine: Lb9
Transmission: M20
Look at southbay Delphi’s, the d3 will work but kinda loud and may need to be tuned for if lean.
Old Jun 10, 2021 | 10:26 AM
ksattic's Avatar
Car: 1987 T/A GTA
Engine: 5.7 TPI
Just spoke to Frank at Southbay and ordered the Delphi 22lb injectors and FPR kit with gaskets.
Old Jun 19, 2021 | 01:14 PM
ksattic's Avatar
Car: 1987 T/A GTA
Engine: 5.7 TPI
Got the fuel rail off - fairly straightforward. One of the injectors is missing a pintle cap! They appear to be the originals, and from what I can tell there's no way that the cap can fall into the engine due to the diameter. I was able to remove the o-ring.
The pintle caps are on there really tight - I'm puzzled how this could have happened? Any chance it's been like this since the factory or should I stop everything and get a scope to look inside the cylinder?
Old Jun 19, 2021 | 01:27 PM
ksattic's Avatar
Car: 1987 T/A GTA
Engine: 5.7 TPI
On closer inspection, most of the pintle caps have pieces missing with no sign of them anywhere.
2012sergen11
Feb 7, 2016 11:12 AM
BlueWrath92
Oct 9, 2013 02:41 PM
zzjakect
Feb 22, 2013 11:23 PM
ecalderon
Sep 14, 2010 02:16 AM
Bobby_80s
Jan 3, 2007 11:30 AM
