Too much fuel to engine!
Old Sep 13, 2010 | 01:47 AM
ecalderon's Avatar
Car: 1987 Iroc-z28. 5.7
Engine: 5.7 350 Engine
Axle/Gears: ???
Ok. So im new on here and i could realy use your guy's help. 8 months ago i bought an 87 camaro. 5.7 all stock. evrything is good exept one little problem.....it shoots too much fuel through the fuel line to the engine to the point where i had fuel coming out the intake!!! i replaced the fuel pressure regulator and that wasnt it. the only way i can get it to start and drive is by jamming screws in the fuel lines so that it doesnt pass so much fuel. Much help would be apreciated....Please!
Old Sep 13, 2010 | 09:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Too much fuel to engine!
What's your fuel pressure, where was it coming out the intake, and where were you jamming screws in the lines?
Old Sep 13, 2010 | 04:19 PM
ecalderon's Avatar
Axle/Gears: ???
<a target='_blank' title='ImageShack - Image And Video Hosting' href='http://img153.imageshack.us/i/tpi1.jpg/'><img src='http://img153.imageshack.us/img153/2556/tpi1.jpg' border='0'/></a>
Uploaded with <a target='_blank' href='http://imageshack.us'>ImageShack.us</a>
this is where im talking about. this little spot here.
<a target='_blank' title='ImageShack - Image And Video Hosting' href='http://img844.imageshack.us/i/tpi2.jpg/'><img src='http://img844.imageshack.us/img844/9510/tpi2.jpg' border='0'/></a>
the circle is where i have a screw in so not that much fuel can pass and drown my engine. and as you can see, the square is where the part shoots too much fuel. it was leaking when i went to disconnect the fuel line to take the picture
Old Sep 13, 2010 | 04:21 PM
ecalderon's Avatar
Axle/Gears: ???
Attached Thumbnails Too much fuel to engine!-tpi1.jpg   Too much fuel to engine!-tpi2.jpg
Old Sep 13, 2010 | 04:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well to start with, that's not a fuel line, it's the manifold vacuum reference line for the fuel pressure regulator. If it's leaking from there, you've got a bad diaphragm in the regulator.
Old Sep 14, 2010 | 01:48 AM
ecalderon's Avatar
Axle/Gears: ???
The regulator is 4 months new tho. the old one i replaced was cracked and rusty.
Old Sep 14, 2010 | 01:52 AM
Kozusnik's Avatar
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
It should come with some type of warranty try to get a new one and see if maybe you gotten a bad one it happens!
Old Sep 14, 2010 | 02:14 AM
ecalderon's Avatar
Axle/Gears: ???
Alright. cool thnx. i'll replace it and keep u posted. it wudnt hurt to try
Old Sep 14, 2010 | 02:16 AM
Kozusnik's Avatar
Sounds good man! Try to get it replaced under the warranty! Let me know if this don't works I have other ideas.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
