Crane 2032 cam
Old Aug 30, 2021 | 04:59 PM
silverstang84's Avatar
Car: 88 IROC
Crane 2032 cam
I want to get a 2032 cam for my 88 L98. Can’t seem to find this camshaft. Looked at Summit, Jegs…. Even emailed a few places. Has it been discontinued?
Old Aug 30, 2021 | 06:26 PM
NoEmissions84TA's Avatar
Re: Crane 2032 cam
HFT or roller?
Old Aug 30, 2021 | 07:29 PM
Car: 88 IROC
Re: Crane 2032 cam
Either
Old Aug 30, 2021 | 08:46 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Crane 2032 cam
https://www.thirdgen.org/forums/tech...4666492-a.html
Old Aug 30, 2021 | 09:23 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Crane 2032 cam
Old Aug 30, 2021 | 09:32 PM
goldandblue's Avatar
Car: 1988 GTA
Re: Crane 2032 cam
Originally Posted by gwarren007
what ya got there?
Old Aug 30, 2021 | 09:44 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Crane 2032 cam
Originally Posted by goldandblue
what ya got there?
Crane 2032 from GM
Old Aug 31, 2021 | 02:18 AM
Car: 88 IROC
Re: Crane 2032 cam
Thanks to a member on here I have located the GM equivalent to the 2032. Thanks guys
Old Aug 31, 2021 | 07:10 AM
Car: 1988 GTA
Re: Crane 2032 cam
the one from gwarren or you find another one?
Old Aug 31, 2021 | 07:22 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Crane 2032 cam
He found another one. I still have mine.
Old Aug 31, 2021 | 09:27 AM
Car: 1988 GTA
Re: Crane 2032 cam
are you looking to sell it? Do you have the specs for it?
Old Aug 31, 2021 | 01:46 PM
Car: 88 IROC
Re: Crane 2032 cam
Yes sorry I found another one. I didn’t see a link or pic posted above
Old Sep 1, 2021 | 11:44 AM
Car: 1988 GTA
Re: Crane 2032 cam
Anyone have one or a gm equivalent they want to sell?
Old Sep 1, 2021 | 12:13 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Crane 2032 cam
My car had that cam when I bought it, there are way better cams out there for the money. $.02
Old Sep 1, 2021 | 12:34 PM
Car: 1988 GTA
Re: Crane 2032 cam
ill will gladly take those other $.98 please expand. My goal was a cam i could upgrade to without having to change a lot of stuff. This may be stupid to many but my gta has the digital dash. Probably my favorite part of the car. I dont want to do something that would cause me to not be able to use it or have to replace it.
Old Sep 1, 2021 | 12:51 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Re: Crane 2032 cam
I think that cam is 214-220 @.050 and something like .452.460 lift. What mods are on the car now? Are you going to change springs and lifters with the cam change if you are using stock heads?
The guy I bought the car from had the 2032 cam in a 383 with AFR heads because he didn't want to pay for chip tuning.
You need to list out what you want to do with the car and go from there with a parts list.
Old Sep 1, 2021 | 01:36 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Crane 2032 cam
MAF cars will do fine on this cam without tuning.
Old Sep 1, 2021 | 11:48 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Crane 2032 cam
Show me all the new roller cams from GM for 100.00 or less for gen 1 SBC , i will wait.......
Old Sep 2, 2021 | 08:12 AM
Car: 1988 GTA
Re: Crane 2032 cam
All I have done at this point are headers, y-pipe, GMMG 3" exhaust. I also have a tune from Tuned Performance. She sounds great. My goal is to have a little more fun stop light to stop light. I want to keep the Dash intact. I would do springs and lifters if needed. I did not plan on changing heads but would port them if it would help. I am green. All your typical things one does to a car I can do. Oil, breaks, general maintenance etc. I have never and wouldn't try to put a cam in a car. I have a shop that I would trust to do the work but I don't feel like they are super knowledgeable on 30 year old tpi motors as far as being able to "engineer" a plan. They could certainly execute the plan. I am assuming these GM cams are no longer available to purchase?
Old Sep 2, 2021 | 11:53 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Re: Crane 2032 cam
Who is looking for new cams from GM for less than 100? If you want to make HP then you have to pay.
Old Sep 2, 2021 | 11:58 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Re: Crane 2032 cam
https://www.lingenfelter.com/product...l#.YTECJvpKiM8 The 211/219 LPE cam works. I ran the 219/219 and made good power with it but that was with the superram intake.
Call Lloyd Elliot and see if one of his cams will work for you: http://elliottsportworks.com/?page_id=32
Old Sep 2, 2021 | 01:06 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Crane 2032 cam
Crane 2032- $439.06
GM 94666492 $100
and its the same cam. Could you spend 300.00 somewhere else? I could
Old Sep 2, 2021 | 06:35 PM
BadSS's Avatar
Re: Crane 2032 cam
Crane 2032- $439.06
GM 94666492 $100
Have you measured the cam to be sure it's the same? Maybe at one time it was made by and had the same specs, but with folks measuring different durations (below) I don't think I would trust that it's the same now.
A post from here: https://www.thirdgen.org/forums/tech...ml#post6419329
Originally Posted by morgsie
Figured I'd revive this thread and post what I found with this cam. I bought it a few months ago for $165 canadian. friend of mine has 350 that we rebuilt going in his boat with vortec heads. I had a LT4 hotcam that i've had for years but it was out of his price range (hotcam is $600+ canadian now!!!) . anyway we installed today and put a degree wheel on it. Now keep in mind intake was already installed and i measured off the push rod with my dial indicator... I know not ideal, but still works. 202/210* duration @ 0.050". I installed a 2* offset key and got ICL 108* & ECL 117*. 112.5* LSA, lift was 0.300"/0.310" at the lifter. Good enough for what we are doing, but ~10* less than what is mentioned here.
A post from here: https://www.offshoreonly.com/forums/...ml#post4673174
Originally Posted by homeboy
My degree wheel made it in. With low lighting and cold temps I am coming up with 205-207 intake and 212-213 exhaust duration, I'll spend a little time in the daylight figuring it out tomorrow. Absolutely no way it is going to be that Crane with 214/220. (He measured the lift at .300/.310 or .450/.465 earlier)
Old Sep 2, 2021 | 07:31 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Crane 2032 cam
No I haven't measured it as the 305 I have is in a "parts" car. Can I believe Fast355 (member) and Crane who sent the cam card over someone I have no knowledge over? Yes
tmviper
Oct 30, 2007 04:18 PM
5.8L Camaro
Dec 28, 2004 03:30 PM
JokerRS
May 5, 2003 05:45 PM
5.7lformula
Feb 13, 2002 06:57 PM
