Bad Mass Airflow Sensor
Old Apr 12, 2022 | 02:17 AM
Schmidi's Avatar
Hi there
i did a engine swap on my 88 305 tpi camaro. i put in a 350 sb out of a 86 corvette with tpi. now the engine runs quite good, but not perfect. when the engine is reaching normal temp. idle begins to wave down and up and it runs way to rich. i changed the injectors, the sparkplugs, the knock sensor, the esp module, the distributor incl. cap & rotor and and put in a new programmed prom. if i disconnect the airflow sens the engine runs just better in limp mode. in my understanding is this a sign for a bad airflow sens. would you agree? what do you think about the granatelli adjustable airflow sensor?
thanks for any help....
stefan
Old Apr 12, 2022 | 10:06 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Bad Mass Airflow Sensor
You don’t need a adjustable maf delphi is a good replacement. What are grams per second showing maf plugged in ?
maf disconnected code 33 or 34 ?
runs off tps input
Old Apr 14, 2022 | 04:54 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
What codes are you geting?
Old Apr 15, 2022 | 03:24 AM
Schmidi's Avatar
I Have no Codes. It just idles unstable if the engine is hot and it runs that rich you can smell it....
irockid43
Jun 2, 2012 12:25 AM
Tpx
Oct 6, 2010 06:55 PM
ninetyone
Oct 28, 2009 11:18 AM
droppedbagged72
May 7, 2006 03:50 AM
Bruce89TA
Oct 3, 2002 06:15 PM
