Failed emissions bad
Hey all, went through emissions and failed with 3x the HC and a little high on Nox. I think the Nox will go down once i sort the high HC. Have a 1989 Firebird with the 5.7 TPI.
It starts and runs great, does smell rich though.
I have new plugs, cap and wires coming. Will also check for leaks after that. Anything else you all can point me at?
They almost killed it via overheating, have to come up with a plan for next time i go back. Thinking one of the carpet blower fans and telling them to use that as well. The fan they have even pointed down is way to high.
Ash
Ash
Transmission: T-5, TH350, T-5
Re: Failed emissions bad
What injectors? What tune? What is your timing at? What do the plugs look like? What exhaust is on it?
Might want to change the O2 sensor while doing tune up stuff too.
Will be getting a timing gun to check the timing. Stock exhaust is still there, cat included.
Will update on plug conditions once I get the tune up done.
Ash
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Make sure the EGR vacuum line is connected. Mine popped off years ago I failed for high NOX
Transmission: Pro-built 700R4
Start with the timing after a good tune up. I typically have to retard my timing to 4* for my car to pass smog.
