need a distributor
need a distributor
MSD Ignition 8366 MSD Pro-Billet Ready-To-Run EFI Distributors | Summit Racing
Is this worth the money ??? Doesn't seem so reading the reviews.
Think I'm going to rebuild my 80,000 mile OEM unit. I'd gladly spend the money, but the reviews are **** poor.
Engine: 5.7 L98
Re: need a distributor
I found a AC Delco reman but it was near $300 but has worked well the last few years. It came with a new GM ignition control module too.
For aftermarket performance the DUI (Davis Unified Ignition) seem like the best out there, not cheap at a little over $300 but they are supposed to be good quality and excellent performance.
Engine: 5.7 L98
The only problem I had with the distributor since day 1: Rust would collect under the cap & rotor, and I would have to vacuum it out every 10,000 miles. Like a little pile of rust.
Car: 1989 Camaro IROC Z
Transmission: 4L60
Axle/Gears: 2.77 G80 9 bolt
Engine: 5.7 L98
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Been running an MSD distributor for several years with the only issues being one of the terminals on the module snapping off, I'm guessing due to corrosion and/or the tension on it due to the short wire from the pickup. Replaced both, cleaned up and good as new.
Transmission: 4L60
I think the 369 is the same as the D1943A from what I've gathered. I'm trying to figure out which ICM is supposed to be my 1989 L98 F Body distributor. There's a D1978 in it now and that belongs in a mid 90s TBI truck it looks like. The only thing that trips me up about the D1943A/369 is it says it's for non-HEI applications. My 89 definitely has HEI with a remote coil.
Engine: 5.7 L98
If you want to get deeper into this I would start your own thread, you will get better responses to exactly what you are asking.
Car: 1989 IROC-Z
Engine: L98 350 TPI
I brought a $65 Chinese distributor from Rock Auto, fully loaded. Cap & Rotor & everything. Dropped it in, fired right up. Car idles better than it has in 15 years. and I didn't even put a timing light on it yet.
OE distributor was trashed at 78,000 miles.
