Error code 34 and maf relay confusion - 88 gta.
Old Oct 23, 2022 | 05:09 PM
Reddwarf's Avatar
Car: 88 trans am gta
Engine: 350 tpi
Axle/Gears: Stock
I have issues with error code 34 and is about to replace the maf power relay. Searching this city and a few others I got the impression that there should be 3 relays to the left of the brake booster on a 88 gta. 2 oval and 1 square.
The square one should be fuel pump, and the 2 oval ones, maf power and maf burnoff respectively...
However, on my car the square relay is marked "MAF power" in big red letters. What gives? Is the Internet wrong, or can you actually use a maf power relay from an older tpi car as fuel pump relay? 🤔
it would be nice if i somehow could verify that the square relay is indeed not the maf power relay, before I spend time and money on the wrong relay....
Old Oct 23, 2022 | 05:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Error code 34 and maf relay confusion - 88 gta.
Maf power is the older non weatherpak relay iirc it’s marked on the top.
Old Oct 23, 2022 | 05:22 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...have-part.html
the maf power might be the same as older 86-87
Old Oct 24, 2022 | 01:43 AM
Reddwarf's Avatar
Engine: 350 tpi
Axle/Gears: Stock
Thanks,
That image helps alot. Since it have colors on the wires it should be easy to verify. 👍
/Leif
Chevy86 IROC-Z
Nov 6, 2009 03:38 PM
bigchief
Jul 21, 2007 06:38 PM
MasterEvilAce
Nov 27, 2003 06:44 PM
TunedportROC
Nov 23, 2003 09:46 PM
Quiet Bob
Apr 10, 2001 10:46 PM
