Looking for hot water under Plate
Old Apr 9, 2023 | 10:47 AM
racprops's Avatar
Looking for the stock hot water under plate/housing to warm the Throttles and contains the idle motor for the TPI premium.
Throttle Body LT1 Coolant IAC Housing.
Clean used would be great.
Rich
Old Apr 9, 2023 | 11:27 AM
Vader's Avatar
Re: Looking for hot water under Plate
Are you trying to acquire a replacement water passage for the throttle body? I know the aftermarket replacement TBs (like BBKs) are not usually supplied with the coolant passage, although they are often set up to accept one
Old Apr 9, 2023 | 11:44 AM
racprops's Avatar
I am working with a TPI system and it seems all three had a little housing on the underside of the throttle housing to run hot water though to heat throttles.
It also contains the idle motor.
One was cut and modified to just the idle motor and the other is broken, and the third is fairly corroded...
Rich
Old Apr 9, 2023 | 01:17 PM
racprops's Avatar
This part, it is called
throttle body coolant cover
Old Apr 9, 2023 | 02:01 PM
racprops's Avatar
And four of the round head Star Driven large bolts for the manifold to head.
Old Apr 9, 2023 | 07:31 PM
Vader's Avatar
The piece in your photo actually does not look all that bad from the visible side. A little cleaning and anodizing might just make it serviceable and durable.
Old Apr 9, 2023 | 07:36 PM
racprops's Avatar
It is OK, but the two other ones are: one was cut down to just the idle motor and the other one is broken.
I figure best to see if I can get replacements now, than later...
Also I will need gaskets.
And those for manifold to head bolts.
Rich
Evilokc
Feb 15, 2022 12:20 PM
toxik IROC
Exterior Parts Wanted
Jul 3, 2011 09:25 AM
8UpAFord
Jan 31, 2006 05:00 PM
bob8748
Dec 5, 2002 12:30 AM
