TPI Distributor
Car: 1988 IROC
Engine: 383
Axle/Gears: 3:42
TPI Distributor
Does TPI engine require a specific distributor or can I use any sbc? I have an HEI new but I also have the original that came on the TPI engine.
Thanks!
Thanks!
Transmission: T-5, TH350, T-5
Re: TPI Distributor
You need to use a factory type computer controlled distributor. There are only 3. Small cap, large cap with screws to hold the cap down and large cap with L clamps to hold the cap down. That's it. No secret. No vast array. Just buy a quality one. Performancedistributors.com is such a place though you can probably buy one from summit or jegs or rockauto with good results.
Which distributor is on you car now? Why do you want a replacement?
Car: 1988 IROC
Engine: 383
Axle/Gears: 3:42
Re: TPI Distributor
I have a crate engine that I am installing and it has the large HEI distributor in it and wasn't sure if it would work.
I have the one that came with the original engine, it's a small cap with external coil.
Also using Fitech Standalone controller.
Thanks for your reply!
Re: TPI Distributor
If using an FItech system, you will need to use what that system requires. The tpi itself is of little consequence in this case since you're not using the factory type ecm.
I'm not quite sure the requirements for FItech though any paperwork or their website should provide that information.
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: TPI Distributor
FiTech requires small cap external coil as per the instruction manual, which I would suggest reading. They also do not provide the subharness that goes from the coil to the distributor, I got mine from Michigan Motorsports.
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Re: TPI Distributor
I recently replaced my distributor with a NOS GM Performance part. No regrets.
Here's a link to my thread. Might help answer some of your questions.
Linky
Linky
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Distributor
https://www.facebook.com/groups/tunedperformance/permalink/1005783623774034/?mibextid=W9rl1R
instructions on how to rewire small to large cap icm on fitech
dynosoar
Sep 6, 2009 05:25 PM
