Chasing my tail
Old Sep 8, 2023 | 06:05 PM
Chaddyboy's Avatar
Chasing my tail
Ok so if.made a few post about my 87 iroc and running crap issue.So most new.parts thrown in just bought a new set.of Delhi injectors from south bay injectors .Thanks to them.So but everything back togeather and it seems it finally is idling good.Then my light bulb came on and inrealized i forgot to plug in the fuel pressure reg yikes.So went out side reattached vacuum line to plenum start it up and dammm same crap idling.Unpluggg vacumm line and it runs like like did before surges up and down ect.Wtf is going on.
Old Sep 8, 2023 | 06:20 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Chasing my tail
What code is it throwing? What is your fuel pressure with the vacuum line connected and disconnected?
Old Sep 8, 2023 | 06:25 PM
Chaddyboy's Avatar
Re: Chasing my tail
No codes and when I tested connected it was 43 and holding .Never tested vaccumm unplugged.
Old Sep 8, 2023 | 07:10 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Chasing my tail
What is your fuel pressure?
Old Sep 8, 2023 | 07:12 PM
Chaddyboy's Avatar
Re: Chasing my tail
it's 43 psi and holding during testing
Old Sep 8, 2023 | 07:16 PM
Engine: 5.0
Re: Chasing my tail
Does it run better with vacuum line disconnected but plugged? (Higher fp, just no vacuum leak)
give a rundown of your symptoms again please
Old Sep 8, 2023 | 07:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Chasing my tail
Despite being delphis sounds like you need a afpr or a tune . It sounds lean if surging.
what is Blm/int at idle ?
Old Sep 8, 2023 | 08:30 PM
Chaddyboy's Avatar
Re: Chasing my tail
runs smoother with reg not plugged in .As soon as you plug it in to vacumm it's a it it show
Old Sep 8, 2023 | 09:37 PM
Vader's Avatar
Re: Chasing my tail
The ECM has an integrator to SLOWLY write the updated to the BLM. Since it was started with the FPR in "bypass" mode, it may be worthwhile to disconnect the ECM power to clear everything and let it re-learn with everything connected correctly.
Old Sep 8, 2023 | 09:59 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Chasing my tail
Can this be accomplished by disconnection the battery?
Old Sep 9, 2023 | 12:50 PM
Vader's Avatar
Re: Chasing my tail
One method is to disconnect the battery. If you have a radio with presets and would rather avoid setting that up again, another method would be to remove the 20A inline ECM/FP fuse located near the battery. As long as the ignition is off, pulling that fuse should remove any ECM backup power.
Old Sep 9, 2023 | 01:39 PM
Chaddyboy's Avatar
Re: Chasing my tail
Well thanks for that. However the issues continues.I know understand why when i disconect the vacuum the psi on my fuel pressure tester goes up and when its plus back in it it goes down whichbtells.me the diagram inside the regular is doing its job.What i cant understand why it revs high then low.Could it be the fuel pump is crappy??
Old Sep 11, 2023 | 05:02 PM
Chaddyboy's Avatar
Re: Chasing my tail
update just put a new fuel pump in and when the car is running the presuure is to high 80psi
sixty3
Oct 24, 2022 10:42 AM
tommygun
Apr 21, 2009 05:52 AM
19formula30589
Jul 7, 2008 08:59 AM
Jas89TTA
Apr 29, 2001 01:09 PM
