L98 TPI
Old Jan 5, 2024 | 12:48 PM
dansm's Avatar
Car: 95 camaro z/ 90. 350. irocz
Engine: lt1 on 95. 350 tpi on 88 iroc
Transmission: auto on both
Axle/Gears: 9 bolt On Iroc.10 on 95 Z
L98 TPI
Does anyone know where I can get valve center bolt gasket. My valve cover has a sheen of oil, so I'm guessing it's probably licking from there.Also some oil on the manifold thank you in advance
Old Jan 5, 2024 | 01:14 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: L98 TPI
vs50088r felpro is the gaskets, if you want the bolt washer you might contact a local gm dealer. I think there copper. Or can remove and clean and use a slight amount of rtv on the washer to seal. The stock covers have tubes the bolt goes through on f body stamped steal covers so there shouldn’t but much oil getting up to the bolt head. The manifold could be wicking up the intake bolts . Liquid teflon on clean threads helps control this.
Old Jan 5, 2024 | 01:28 PM
dansm's Avatar
Re: L98 TPI
vs50088r felpro
thank you
Big&BadGTA
Jun 15, 2020 09:59 PM
I_R_O_C_Z_2_8
Nov 20, 2009 04:31 PM
KYLE87
Mar 15, 2008 04:35 PM
Dens71TA
Jan 27, 2008 04:53 PM
Z's r Best
Jun 20, 2005 11:18 PM
