Engine stalls under load
Old Mar 10, 2024 | 02:57 PM
ShaneMoore's Avatar
89 5.7 iroc / 57k mile - wife surprised me w one that looks great. Owner thought the driving issue was a fuel filter or pump.
idles fine, sounds fine w throttle while in park. Under a load it runs terrible. No power when u mash the gas and it stalls. I replaced fuel filter, no change. Inspected MAF, it looks new (Delphi brand). Just curious if anyone has ideas before I find a shop.
Old Mar 10, 2024 | 03:48 PM
bloodhound1's Avatar
Re: Engine stalls under load
As you mention, could be fuel pump. Symptoms sound fuel pressure related. Checking the fuel pressure would be my first step.
Old Mar 10, 2024 | 05:14 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
probably fuel pump - easy to check pressure with a schrader valve gauge
Old Mar 10, 2024 | 05:36 PM
erik69&85's Avatar
Agree it sounds fuel related.... A clogged fuel pump inlet for me resulted in similar symptoms....mine had rust pickup from the tank...
Don't expect a Delphi maf to be a good thing though... They have known issues... Mostly that they don't read correctly at low airflow... I had to fake mine out to get the car to run right ... Ended up finding an original Bosch... Greatly improved the performance....
bt82681
Sep 13, 2011 07:27 AM
lopezstud87
Dec 26, 2009 07:28 PM
88fbird
Aug 31, 2004 10:16 PM
RyanPoser
Nov 26, 2003 10:52 PM
1988bird
May 29, 2003 05:50 PM
