Reman 5235302 Fuel Injector Rebuild Question
Old Oct 6, 2024 | 12:36 PM
JuanZ28's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 5.7 TPI
How to replace plastic spacer?
I have a 1988 5.7 TPI Camaro that I would like to reinstall the original injectors. I bought a fuel injector repair kit.But can figure out how to remove or install new plastic spacer.
Old Oct 7, 2024 | 02:40 PM
southbay08's Avatar
Re: Reman 5235302 Fuel Injector Rebuild Question
Are the plastic spacers in good condition? They are basically there to hold the oring in place. If they are in good condition just leave them otherwise you're going to have to pull off that metal piece on the bottom. You should be able to get an oring into the groove without removing anything
Old Oct 7, 2024 | 06:17 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Hi, and thanks for the reply. One of the injectors, spacers was cracked and fell apart when removing the o ring. Now I have to install a new spacer but found out that the spacer won't go over the pintle.
Old Oct 7, 2024 | 06:39 PM
southbay08's Avatar
the other thing you can do is take a box cutter and split the ring at an angle. If they are new they should have plenty of flexibility so you should be able to get in onto the injector without a problem. . Getting that pintle cap off will be a real nightmare
let us know if you have any other questions
Old Oct 7, 2024 | 07:10 PM
JuanZ28's Avatar
Engine: 5.7 TPI
got thank you.
gstarnes55
Alternative Port EFI Intakes
May 29, 2007 09:31 AM
Syn
Jul 28, 2006 08:16 AM
AGDrake57
Jul 30, 2004 12:43 PM
age
Aftermarket Product Review
Jan 26, 2004 07:37 PM
RED92BIRD305
Aug 14, 2003 02:45 PM
