IROC transplant into a1955 Chevrolet sedan. I had the filter coming through the radiator support, then just behind as shown. I've even removed the filter entirely! I keep getting Code 34 MAF Sensor Low regardless. Can anyone offer any advice?
Can't imagine this is causing the code. What is the history on the MAF sensor? What brand is it? I don't run a MAF car but have heard the aftermarket units are problematic I think?
I was more curious about the actual voltage measured at the MAF, and not the converted g/S value that the ECM thinks it is seeing.
I took a picture of every screen of the OBD1 while checking for errors, and none of them had that category. Is it something I need to physically check?
You can't read the maf voltage with a simple scan tool. It can be done with modified programming and more sophisticated scanning/tuning tools that can also be modified accordingly.
However, the MAF voltage would be between 0.00-0.090 volts (calibration dependent), which is why it is setting a Code 34. Are we sure that the maf is even being powered? Check the maf power relay and related wiring.
6 gm/sec would be about 0.00 volts (if using a 305 bin like APYS) which is less than the 0.140 volt threshold, so this value is consistent with the Code 34 failure detection settings. Sorry, I tend to forget about 305 bins.
Have been sidetracked for a few days, and will be off and on for the coming week, but I want to wrap my head around what you are telling me. Some of this TPI stuff is beyond my scope of my experience, and that's why I am appreciating the fact you are offering assistance. What should be my next step?
