What injectors are these ?
Old Feb 8, 2025 | 09:14 PM
pete2833's Avatar
Car: 1986 Camaro Iroc
Engine: 5.0 TPI
Not that it matters. Just curious.
I bought this 85 Iroc with 71,000 miles on it.
was sitting for 10 years.
I’m restoring it from the interior to the body to the engine. I have the fuel system out. Tank out.
intake off.
New tank and injectors from South Bay.
Rebuilt the TPI fuel rail today.
Anyone know what injectors these old ones are that were in the car ?
Numbers on one side are 5-235-047
The other side 0-280-150-222
Thanks.
Old Feb 8, 2025 | 10:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What injectors are these ?
19#hr bosch
Old Feb 9, 2025 | 06:57 AM
pete2833's Avatar
Engine: 5.0 TPI
Thanks. Worth keeping ?
Old Feb 9, 2025 | 08:11 AM
Engine: Lb9
Transmission: M20
If they ohm out okay might be worth keeping. But in order to use them they will need to be cleaned and flowed. Assuming none are stuck shut with varnish.
Old Feb 9, 2025 | 08:20 AM
pete2833's Avatar
Engine: 5.0 TPI
I bought a set of new Delphi injectors.
I will keep them as spares for now.
They definitely have a different spray tip than the Delphi’s
Old Feb 13, 2025 | 01:12 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I kept mine. But I also at least did the "home cleaning" with a battery, jumper wires and can f cleaner.
Yu might want to do that to clean out any gunk in there so it doesn't harden / get worse over time.
Old Feb 13, 2025 | 01:14 PM
pete2833's Avatar
Engine: 5.0 TPI
Never did the home clean method.
What’s the procedure ?
Old Feb 13, 2025 | 01:23 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Basically just using a can of cleaner jury rigged to the unit to spray out any gunk. I thin k iuseda 9v battery though. But same idea as this video.
Old Feb 13, 2025 | 02:55 PM
pete2833's Avatar
Engine: 5.0 TPI
Fuel injector cleaning without expensive tools - YouTube
Thanks for the tutorial ! Much appreciated
KyleF
Aug 27, 2019 07:31 PM
GM Man
Oct 23, 2013 06:04 PM
Dmorrow
Aug 14, 2011 08:34 PM
p8dnful
Jun 12, 2010 05:00 PM
spedrace35
Dec 9, 2005 06:58 PM
