TPS voltage
Car: 1989 IROC-Z, 1970 Camaro SS
Engine: 5.7
TPS voltage
Recently inherited a 1986 IROC and working out issues with it. It had sat for a few years before I got it. Trying to set TPS voltage but lowest it will go is .96v. Swapped out TPS sensor with same results. Throttle plate is closed. What am I missing?
Transmission: T-5, TH350, T-5
Re: TPS voltage
Test one without it being bolted to the tb, just connected to the wiring. Maybe its a limit in the range physically for some reason we can't see.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPS voltage
Was minimum idle speed set before tps was attempted to be adjusted?
Engine: 5.7
Engine: 5.7
Engine: 5.7
Re: TPS voltage
What kind of meter is being used? Does it have a recent calibration label? Splitting measurements down to the millivolt range is no place for a "Boris" instrument that might be accurate to ±10V. That includes most of the automotive market tools, like the kind off the back of a roving ice cream truck, or those hanging on the wall at the parts chain stores that also sell oil treatments, synthetic car wash, and "Kamala-scented" air fresheners.
