LT1 intake conversion on ZZ4 heads
Old Feb 1, 2002 | 05:13 PM
Steve10's Avatar
John Millican is modifying an intake for me. Anyone know of any differences when using ZZ4 aluminum heads? I can't wait to get this swap done and let this thing breathe. I have a G-tech, so I should be able to get some before/after #'s for a LT4 hot cammed ZZ4 with LTR vs. LT1.
Old Feb 1, 2002 | 07:49 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
The zz4 heads contain the pre-86 bolt pattern for sbc heads. SHould be no problem. I believe he cuts them for both style heads.
Old Feb 1, 2002 | 08:19 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Ah, that's what we needed to know. Hee i thought the NEW ZZ4 would have the newer bolt pattern intake/head on the center two intake bolts.
So it's the old style huh?
Old Feb 1, 2002 | 09:34 PM
Steve10's Avatar
John, I'll get a chance to confirm it in the morning. I can't believe I was too busy today to even go take a look.
Old Feb 1, 2002 | 09:40 PM
Earl 87gta's Avatar
Ya they are the old style the zz4 heads are the same as the L98 58cc alumminum vet heads.
Old Feb 2, 2002 | 01:18 PM
Steve10's Avatar
That's weird, so these heads have the centerbolts which is 87-up, but have the bolt pattern of pre-86. It's hard for me to tell for sure with these runners in the way, but take a look at the pic below. It looks to me like the center bolts are not angled. I'm guessing they would be more toward to the South end of the intake slot if they were.
Old Feb 2, 2002 | 02:08 PM
91-ZZ4-Z28's Avatar
yes they are old style heads.
Old Feb 2, 2002 | 02:11 PM
rhuarc30's Avatar
Earl is right the zz4 heads are the same as the corvette l98 heads, but with upgraded springs and stuff, says so right in the gm performance parts manual.
This high-permormance cylinder head assembly is used exclusively on High Output 5.7-liter small block V8 engines. Unlike production Corvette cylinder heads, it is outfitted with specil heavy-duty valve springs.
Straight from the pace website
But I believe that for a while places like Scoggin-Dickey were offering them redrilled for the old bolt pattern, so if it's a used set of heads that's possible. Easy to check though, if the bolt holes aren't at 90* to the intake face it's the newer style, you can just eyeball that the difference is pretty big.
John
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
