Will a LT4 intake bolt up to my heads?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I got a ZZ4 motor w/ corvette style heads and wanted to know if I could put a LT4 intake on it. What are the main differences between these two intakes, bolt holes, flow #'s, etc. Any help is greatly appreciated.
Would it be worth it to send it to John M to modify it for me? Thanks a lot guys.
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Re: Will a LT4 intake bolt up to my heads?
LT1 intake is the only way to go with standard SBC heads.
Car: `86 SS / `87 SS
Let's see. The Vortec heads have ports that are about the same height as the LT1 intake, and both are higher up than an alum. L98 / ZZ4 head, so there's a bit of mismatch there. 0.100 or so.
The LT4 intake ports are even higher (or taller, forget which), and a bit narrower, so that would be even worse.
Mini-Ram it.
Mini-Ram it.
Depends on what heads you are running, Tyler. The LT1 intake is a port mismatch for Gen I SBC heads (pre-vortec) but it does match up real well on the Vortec heads. I'm not sure where fast burn heads fall in, but I believe they are quite close to the Vortec intake ports. The LT4 intake is right for LT4 heads, and unless you're running LT4 heads, you probably wanna stay w/ the LT1 intake, if that's the route you're going. On traditional non Vortec SBC heads, I would go mini-ram.
Engine: 4.0L
Originally posted by jmd
Depends on what heads you are running, Tyler. The LT1 intake is a port mismatch for Gen I SBC heads (pre-vortec) but it does match up real well on the Vortec heads. ..........
The LT4 intake is best suited to vortecs and fastburns.
The miniram is stupid priced.
John please don't call me a liar. You merely discredit yourself.
The LT1 intake has raised ports. Every time I work on my cars I walk past my ZZ4 intake, a 94 Z28 intake, an LT1 longblock from a 95, and an L98 out of an 88 GTA. Do you wanna sit here and tell me the ports aren't mismatched due to being raised? C'mon now.
The LT4 intake has higher and narrower ports than the FastBurns or Vortecs. Mismatch again.
Let's be real. Is the LT1 intake a great value? Yes. Is it properly port matched to an SBC gen I head? No. I am not trying to smack down the hard work and research that you have put into this. But if you want a proper setup, there is port matching to be considered.
Start paying someone else for the ports to truly match up, and the $ gap of the mini-ram drops considerably. I do honestly feel that an AFR & Mini-Ram II motor will run a port mismatched LT1 intake motor out of town. But I certainly don't have the resources to throw down all the parts and dyno time to show it. So let's address the things that are known facts.
Matthew
Matthew
Engine: 4.0L
The LT1 intake has raised ports. Every time I work on my cars I walk past my ZZ4 intake, a 94 Z28 intake, an LT1 longblock from a 95, and an L98 out of an 88 GTA. Do you wanna sit here and tell me the ports aren't mismatched due to being raised? C'mon now.................................................................................................The LT4 intake has higher and narrower ports than the FastBurns or Vortecs. Mismatch again..........................
The LT4 intake and Fastburn/Vortec head? Well that's your only choice if you want to run the LT4 intake. I know there's some porting required. That's why I don't touch them, too much work.
Oh, the Miniram is still stupid priced.
Edit: The miniram or cylinder head you choose will have to be port matched too if you want perfect.
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Well, I just bought an LT1 manifold and I think the ports line up better than my superram base to my AFR heads. Ok, so 1300 for a miniram or 150 for the lt1 intake i just bought. That included rails. So maybe 300 total and no 1,2 cylinder distribution probs?? Sounds good to me
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
re:
Yeah, I gotta agree with you guys.
**Miniram=too much money
** LT1 Intake=CHEAP and great for poor college students like me
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
