Retrofit LT1 intake/EGR question
Old Feb 10, 2002 | 10:29 PM
GTA600's Avatar
I want to modify an LT1 intake manifold and put it on my 383 I'm building instead of using a mini-ram. Either way I won't be able to use my EGR and there is a chance that we will be getting emissions checks that require them looking for the EGR. I was wondering if I could put the EGR in the air duct running from the supercharger to the throttle body if it would still function correctly. If not does anyone else have a solution?
Old Feb 11, 2002 | 05:32 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
That's only have of it. You still need to get exhaust gases to it also.
No, no one has come up with a solution yet.
Old Feb 11, 2002 | 01:10 PM
GTA600's Avatar
Couldn't I bend some kind of pipe off of the OEM pipes coming up from the headers to go to the new location of the EGR? it might look kinda bad but it would still work right?
Old Feb 13, 2002 | 03:56 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I would think that you wouldn't want to put the EGR before the throttle body because you'd coat the throttle blades and passages, as well as the IAC passages with even more soot than they already get, plugging them up a lot sooner.
Old Feb 13, 2002 | 05:14 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
You may want to build a remote EGR similar to the vette, LT1 with a tube off the header into the EGR valve then a tube into the block-off plate on the back kof the intake.
Old Feb 13, 2002 | 11:16 PM
GTA600's Avatar
That sounds like a really good setup I'll see what I can figure out for that. Thanks
Old Feb 14, 2002 | 07:28 AM
Engine: 4.0L
Where's Cartersville, GA? How far from Savannah?
Old Feb 14, 2002 | 09:13 AM
GTA600's Avatar
Cartersville is about 40 miles north of downtown Atlanta.
Take I-75 North to exit 288. That's it!
Old Feb 14, 2002 | 02:43 PM
Engine: 4.0L
Is it named after Jimmy carter? j/k
Too bad your so far, I thought it might be closer to Savannah.
Old Feb 17, 2002 | 10:02 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Ok, so I just bought an LT1 intake and rails. My AFR heads have egr ports. I was wondering how I block these off? John, what intake gaskets do you use?? Just standard SBC ones? I think I may be able just to buy gaskets with no egr provisions, though.
Also, where did you mount your remote thermostat housing?
Old Feb 17, 2002 | 01:12 PM
Engine: 4.0L
I used standard intake gaskets. No worries about the egr ports in the gaskets, the intake side is blocked off.
I mounted my remote t-stat housing on the drivers side inner fenderwell, right in front of where the hard fuel lines are. here's a pic, too bad it's a close up.
Here's a differant angle, follow the upper radiator hose and you'll see it.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
redmaroz
Aug 16, 2015 11:40 PM
