how to completely remove emissions system?
Old Feb 12, 2002 | 05:55 PM
brian89transam's Avatar
the belt on my 87 350 already bypasses the emissions pulley.(I think my mechanic did it) There are no emissions laws in iowa, other than a cat. What parts are not running on my car now? What parts can I remove? The pulley itself probably. What about the canister in the front right of my car? What does it do anyway? I know it's a of questions, but the stuff probably isn't working anyways so I might as well lose the dead weight. Thanks for the help guys. I don't know where I'd be without this message board.
Old Feb 12, 2002 | 07:29 PM
89BlueTA's Avatar
You can lose the pulley and AIR pump, but leave the EVAP canistor, it is venting the gas tank, you need it. Hope this helps
nick
Old Feb 13, 2002 | 07:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
my car does ok without the cannister. Other than an occasional gas smell, it doesn't seem to cause any problems. I'm probably going to put it back in this spring though.
On my IROC I yanked the air pump, and put non a.i.r. headers & cat on. It really cleaned up my engine bay.
Old Feb 13, 2002 | 10:37 AM
Little GTA's Avatar
Is the AIR pump the black box looking thing above the passenger side valve cover with all of the hoses ???
Old Feb 13, 2002 | 10:42 AM
Sometimes when I unscrew my gas cap, to fill it up, I hear a hissing noise (like fumes escaping) does that mean that my canister isn't working? Just wondering, probably a coinsidence.
Old Feb 26, 2002 | 09:40 PM
Seth Maurer
Guest
Posts: n/a
I have eliminated the box too, i figured it was useless. I also hear a hissing sound when i unscrew my gas lid. Will this hurt me in the long run if i dont put it back on?
Old Feb 26, 2002 | 09:49 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
my gas cap does that too and my canister is still hooked up. so i guess that eliminates the idea that the canister takes care of that...
Old Feb 26, 2002 | 11:52 PM
5.7lformula's Avatar
Im pretty sure that when you unscrew the lid its just relieving the pressure in your tank. Thats why is usually says open SLOWLY on the cap. I havent taken anything out yet. Im doin all that when i do the exhaust.
Jesse
Old Feb 27, 2002 | 06:59 AM
BigMike92Z's Avatar
yeah ill be taking mine out when i do the headers....
Old Feb 27, 2002 | 03:22 PM
so should I take it out or not? all of my other stuff is unhooked.
Old Feb 27, 2002 | 05:19 PM
Seth Maurer
Guest
Posts: n/a
I would, more room and other than the hissing from the tank (not sure if thats even the reason for it) theres been no problems whatsoever.
Old Feb 27, 2002 | 07:17 PM
you're still talking about the coffee can looking canister right? I'll have a much better cold air setup with that thing out of the way.
Old Feb 27, 2002 | 07:32 PM
360Iroc's Avatar
there is no problem taking this stuff off the hissing noise is pressure in the tank nothing else...one question is what are the sensors that are in the black box above the air pump. are they still important?
Old Feb 28, 2002 | 09:27 AM
purpleworm's Avatar
My friend dropped a 350 in and put his TPI setup back on and he got rid of the air pump and the coolant block. I used to know what the box was for but it escapes me now. I am going to try to get rid of it because of the clutter. It is a PITA when you are setting the valves too.
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
overdriv
Aug 20, 2015 03:52 PM
