Will LT1 Throttle Body Fit On A L98?
Old Feb 16, 2002 | 04:15 PM
nblanchard's Avatar
Hey all, was wondering if a LT1 throttle body will fit on a L98 Plenum? If not, what is different? I know I have to use a throttle body gasket for a TB with IAC passages built in the TB... anything else beside that?
Reason I am asking is that NOS sells a nice kit for the LT1 that comes with a throttle body with the jets all built in sweeeet.
Old Feb 18, 2002 | 02:21 PM
ssbowtie1's Avatar
I believe the throttle cable hookups are different.
Old Feb 18, 2002 | 03:00 PM
nblanchard's Avatar
Ahhh.. I'll have to check that out... thanx
Old Feb 18, 2002 | 07:02 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The IAC and TPS connectors are differant also.
Old Feb 18, 2002 | 08:17 PM
nblanchard's Avatar
Ok... well, can I not use the TPS and IAC from my TB? And the linkage, that isn't a huge problem is it?
Old Feb 19, 2002 | 05:33 AM
Engine: 4.0L
No you can not swap sensors, they are differant. I'm positive about te TPS for sure.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
