super ram owners?????? WANTED!!!!Vote!
Old Feb 19, 2002 | 05:09 PM
german-motorsport's Avatar
A member of our club got a super ram plenum and runners today, no intake!
The car is a 350 gta stock motor with 40tmls (no air cond)with a T5 and 3.45 rear the car will be used in road races!
With what should he start ???
Open up his stock intake?keep the injectors?58TB?.....
Vote or write your engine meal......
1. This is what he really needs......
expect 13 sec?
2. Do this also .......
expect low 13 sec???
3. A real super ram needs 1000cfm TB , big cam ...dream version?!
real boys run 11sec but that needs.....
Old Feb 19, 2002 | 05:16 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Uh . . . . . . . . .What?
Old Feb 19, 2002 | 06:37 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
man u dont need a super ram to run 13's. check my post, im in the high-mid 13's with only exhaust and small stuff. But since u do have one.......new heads and cam to match would be in order. Maybe some aluminum L98 heads and a zz4 cam or something. That should get u low 13's high 12s if you have all that pus the stuff in my sig at least. converter and built trans is the secret
Old Feb 19, 2002 | 06:40 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
opps forgot the sig
Old Feb 19, 2002 | 10:02 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
What does this have to do with Nitrous or Forced Induction? Moved to the TPI forum...
A.
Old Feb 19, 2002 | 11:16 PM
Todd85's Avatar
1) As somebody else said, I believe any 350 TPI equiped F-body can easily run in the 13's with just some subtle modifications such as a good torque converter, sticky tires and good cool air and fairly unrestrictive exhaust.
2) To expect low 13's.... good torque converter and sticky tires.
3) To go 11's, good set of heads ported out to 260/190 cfm by .550 lift, LPE 74219 cam, good tune, sticky tires, good 2800-3000 rpm torque converter, keep an eye on your weight..... stock shortblock, nothing more is necessary.
Take a look at the following link to see examples of decent running TPI and LT-1 Vettes..... all they do also apply to the F-body.... only real difference is the shape of body, and the vettes on average probably have a 100-150 lb weight advantage vs the F-body... but thats it.
Proven L98 & LT-1 set-ups
hope this kinda helps
Todd
Old Feb 20, 2002 | 12:17 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
How fast do you want to go????? Oh wait it still boils down to how much money you have to spend! Definately get either the Accel or Edelbrock lower intake. Get some nice aluminum heads....AFR if you have the money....maybe Trick Flows or aluminum L98's. Get a 58mm TB and a good ignition system.
After that I would focus on the torque converter and the suspension. These should be your limiting factors after the above engine mods.
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
Poncho92
Aug 7, 2015 08:15 PM
