help with a runner/manifold combo
Old Feb 25, 2002 | 06:34 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i need some serious help here. my next set of mods are coming soon (cold air induction and drag radials), and hopefully these will push me into the high 12s. i am currently running low 13s with the following enhancements : cat back exhaust, open filter lid with k&n, removed screens on MAF, 160 degree stat, relocated MAT sensor, throttle enhancer, airfoil, AFPR, ported plenum. after the cold air & radials, i believe the next restriction is the stock TPI manifold. i am looking for the best upgrade, and dont want to waste my money on parts that wont provide the most power. i am not planning to change my cam or heads anytime soon mostly due to cost and labor. this is a subject im sure alot of members would like to know about. which combination of runners/manifold would work best on a mildly worked 350? should that combo be ported further or siamesed? thanks for any information
Old Feb 25, 2002 | 07:03 PM
89BlueTA's Avatar
Do you want to stay LTR? I really like the LT1 option personally. If you want to stay LTR, I would say the edelbrock base port matched to the AS&M runners. Though's are supposed to be the best. But for cost reasons if I do not go with the LT1, I will go the SLP runners and siamese the stock base to match. Hope this helps!
nick
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
