What Type of SuperRam Base is this?
Old Feb 27, 2002 | 01:06 PM
89IROCZZ4's Avatar
I went to put it on and the bolt holes were straight up and down instead of slanted like my heads. Here is a pic. Is this for an lt1 then?
Old Feb 27, 2002 | 03:19 PM
centaur's Avatar
Car: 1991 GTA
Looks as if you've got an intake for an 85-86 engine, you'll need to take it to a machine shop to get the bolt holes modified to fit 87+ heads. Not a big deal.
Old Feb 27, 2002 | 03:53 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Or give me a good deal on that intake to help fund the proper one for your car.
Old Feb 27, 2002 | 07:08 PM
JucinGTA's Avatar
here I just drilled my inner ones
www.geocities.com/softtailduece01
Old Feb 27, 2002 | 07:12 PM
Shadow's Avatar
Car: 88 GTA Notchback WS6
Engine: 350 with a SuperRam
The manifold you have pictured is Accel part number 74197L. It will only fit LT1's. It was manufactured by Accel to allow the use of the SuperRam plenum/runner kit on the LT1 engines.
Old Feb 27, 2002 | 07:22 PM
Jim85IROC's Avatar
If it's an LT1 intake, why is there a spot for a thermostat?
Old Feb 27, 2002 | 07:27 PM
Guest
Guest
Posts: n/a
Looks more to me like its been welded up where the holes are supposed to be for the SBC heads. Why, I dunno. Its certainly not 85-86 style, center holes are too far apart.
Old Feb 27, 2002 | 07:30 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
exactlly, Ive seen one of the LT1 superrams and It has no thermostat.
The one in the picture just needs drilled like said above
Old Feb 27, 2002 | 07:54 PM
Shadow's Avatar
When the manifold was shipped new from Accel, it included a block off plate for the thermostat. It was easier for them to manufacture it from the same molds as the 74197 than to make an entire new mold. It has not been welded and redrilled. It was cast that way from the factory. Trust me, I've sold TONS of them.
Old Feb 28, 2002 | 10:02 AM
89IROCZZ4's Avatar
so, whats the final? If it is an lt1 intake, can holes be drilled for it to fit an l98?
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
