LT5 like TPI
Old Feb 28, 2002 | 10:03 PM
91z4me's Avatar
LT5 like TPI
I know they are apples and oranges but does anyone see some TPI LTR similarities on this LT5?
Old Feb 28, 2002 | 10:17 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Only difference I see is that its about DOUBLE THE SIZE of a regular TPI! ***, every time I see that engine... well I wont go into it, but that engine is G0D!!! :hail:
Old Feb 28, 2002 | 11:06 PM
rockind78's Avatar
Is it a form of TPI...yes. Very cool actually. One set of runners for low end torque (kinda like what we have) and an ADDITIONAL set of runners that are much shorter and are much better at supporting higher RPM's. There is some sort of control mechanism that actuates which set is being used based on RPM level I believe. Very cool concept for its day.
Old Feb 28, 2002 | 11:28 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I want that engine sooo bad. oh well.. I just am gonna have to stick with the L98 :hail: LT5
Old Mar 1, 2002 | 02:41 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
There are two runners to each cylinder, one for each intake valve. They are the same length but on of them has a computer controlled valve. If the key in the dash is set to full power, and the engine is at operating temp, no error codes are set and so on ... the valves will open at 3500 RPM ( I think that it was that RPM ).
The second intake valve also has a wilder cam profile.
With the valves closed power is limited to the 200 hp range.
Old Mar 1, 2002 | 03:23 AM
Jza's Avatar
Jza
splat
Old Mar 1, 2002 | 07:19 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've seen a highly modded ZR1 with siamesed intake runners. Very cool.
Old Mar 1, 2002 | 08:51 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If I win the lotto, that is what I am going to drop into my Trans Am.
That is the sweetest looking motor.
Old Mar 1, 2002 | 09:52 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
I saw a custom LT5 in some sort of hotrod, I don't remember the car becasue I was so facinated with the engine, at the woosward dream cruise last year. The dude had about 4 inches of a spacer between the top and bottom half of the intake. I am sure this enhanced his low end a little more, but the really sick part was this is were he had his direct port nitrous plumbed to. The whole set-up was chromed and totally covered in drool from all the amazed gaukers. If you have never been to the woodward cruse I highly recomned it. It is towards the end of the summer, in detroit, and it is the largest free spectator event held in this country; last year I think they estimated 1.5 million people attended.
Old Mar 1, 2002 | 01:22 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
There is also a seperate fuel injector for each runner. 16 runners = 16 fuel injectors.
Old Mar 1, 2002 | 01:38 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
That's one of the 4 turbo LT-5's LPE did, I believe. Actually, i'm positive. Check this out.............
http://www.corvettemagazine.com/2001...king/king1.ASP
Old Mar 1, 2002 | 02:30 PM
Zepher's Avatar
I want to know how much that cost. $50,000? what do you all think?
Old Mar 1, 2002 | 06:15 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
$54,000 If you want one, your screwed. They've built 3 and the 4th is reserved for Mr. Lingenfelter's own '95 ZR-1. The horsepower numbers quoted in that article are with the boost turned down .
Old Mar 1, 2002 | 10:37 PM
Hes only runnin 11 flats??? Now, Im saying "only 11's" cause hes got almost 800 horses under that hood... what gives? He should easily be in the 10's, maybe lower, unless traction is his problem.
Old Mar 3, 2002 | 01:05 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Just because you can buy a sweet car doesn't mean you can drive it......
Old Mar 3, 2002 | 08:12 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Are you kidding? Take that $50,000 then double it. Then when you've done that add another 20-50K on top. This is about as exclusive as they come.
I know of someone that has number 3 out of the 4 and he's sent it back for some more mods and to get some lighter body pannels. Neither he or John Lingenfelter will disclose prices of this car.
Robert
Old Mar 6, 2002 | 12:30 AM
FiReBReTHa's Avatar
zzzzbaasssshhaaa SHAWING!!!!
i just got a new background, gawd, that thing turns m----
anyways,
how's this:
"dear santa,
i've been negateable this year, but after all this time of thinking ive concluded that i want to be just like you, your a fast guy, and to be fast illlll neeeed a: LT5
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
