TPI swap info needed
Old Mar 5, 2002 | 06:02 PM
Edzz's Avatar
Hi,
I'm swapping in TPI to my 84 L69 305 soon, gotta few questions, please. TPI is from an '85 305 IROC-Z. I've got 99% of what I need off the donor car.
1. Do I have to change over the alternator, AC compressor, PS pump & AIR pump?
2. I've got a set of Hooker Shortie headers W/O AIR tubes. Can I run these and eliminate the AIR pump completely? Will that throw "codes"?
3. The engine is bone stock, would porting/siamesing the TPI be really worth the effort?
I'm sure they'll be more questions down the road
TIA
Ed
Old Mar 5, 2002 | 09:17 PM
Nasty_Bird_'90's Avatar
1) no, chances are that all the accessories will swap over, as long as you have the same belt system. if i'm not mistaken, the 84 had multiple belts. if you put the accesories from a later model on the 84, i dont think it'll work because they used a serpentine belt ( someone correct me if i'm wrong)
2)yes you can run no smog, no there wont be any codes. just check local emissions laws. your car may be old enough to not have to pass the sniffer
3) yes. the f bodies need all the help. every little bit counts. they;ll do ya more good later on down the road when you have more mods
Old Mar 6, 2002 | 03:03 AM
Jza's Avatar
Jza
Serpentine belts did not start until 88. You should be able to reuse your current accessories and bracketry.
Old Mar 6, 2002 | 09:13 AM
Edzz's Avatar
Hi,
Thanks for the replies. This whole site is like the Fort Knox of 3rd gen info.
The '84 L69 uses a couple of Vbelts, but the '85 TPI 305 had a Vbelt and a serpentine belt. My current accessories all work great, and I'd like to keep them if possible. I just wasn't sure if there'd be clearence problems with the dual snorkle (or something like that) by keeping the original Vbelt set-up. I guess it'll be trial & error.
I'm happy to hear I can ditch the AIR pump. The factory pollution hoses under this hood are a plumber's nightmare.
Just thought of another question, tho...
Will I need a new throttle & 700R4 tranny kickdown cable?
Thanks,
Ed
Old Mar 6, 2002 | 01:15 PM
dual snorkel? why not forget about it fitting and just put in a nice open air element?
as for the cables, i think the stock ones will work, not positive though. in know, im worthless.
Old Mar 6, 2002 | 01:25 PM
Edzz's Avatar
I was planning on gutting the airbox & rigging-up a cold air / ram air set up.
Ed
Old Mar 8, 2002 | 01:57 PM
Edzz's Avatar
Anyone else, please?
Will I need a new throttle cable? Or a (700R4) tranny kickdown cable?
Thanks,
Ed
Old Mar 8, 2002 | 03:59 PM
Jza's Avatar
Jza
Yes, the cables will be too short to reach the TPIs throttle body (way at the front of the engine compared to the carb's engine at the middle).
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
