Having Problems
Old Mar 12, 2002 | 05:38 PM
86305's Avatar
Having Problems
I have an 86 tpi trans am with a 305 (lb9). I just put a maf on it tune up replaced the ignition module and the timing is perfect. But for some reason when i stop a to turn or at a stop sign the damn thing cuts off when i'm slowing down. Once the tack gets to about 1000 rpm's it just dies. Not always though. And i'm getting a code reading the vehicle speed control sensor. ANy ideas.
Old Mar 13, 2002 | 07:49 AM
89Raptor
Guest
Posts: n/a
Sounds like a bad MAF.
Old Mar 13, 2002 | 07:50 AM
86305's Avatar
I just put a new one on it which helped it alot. But it still does it occasionaly
Old Mar 13, 2002 | 08:04 AM
89Raptor
Guest
Posts: n/a
Hook up a scanner to it and record until you get the problem to occur and then review the data and see what the problem is.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
