"Rare Factory Intake"
Old Mar 13, 2002 | 11:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1811443165
Anybody know what this is about? I've never heard of such a beast. Those intake ports do look a little larger than stock from what I can tell, although I'm sure it could have just been ported. Anyway... anybody ever heard of this?
Old Mar 13, 2002 | 11:41 AM
CarnageGTA's Avatar
Never heard of this BUT
It might be the same intake as the factory race firehawks...
Have u ever seen the whole top end of those hawks? I like nothing we have. I always woundered if we could slap on that intake and TPI? configuration on a 350.
Hmmm anybody know about those Firehawk engine, specs, numbers...
Old Mar 13, 2002 | 11:57 AM
Drew's Avatar
The Firehawk intake is a completely different intake than your standard TPI intake... imagine a 5.0 Ford intake and you're pretty close.
BTW that sure looks like a stock intake to me... I don't see any part numbers, no close up pics of a ground off part number, and it looks to have typical corrosion/grease/yellowing from being used, and it appears as though somethign is up with the injector bosses... it might be a glare from the machined surface but at least one of them looks like there's an O-ring lying inside the bore.
Also we all know that an aftermarket intake isnt going to be 40hp, and we all know that Edelbrock, Accel, TPIS, etc all sell their bases for not much more than this auctions price. AND the guy has 0 feedback points.
Old Mar 13, 2002 | 12:06 PM
rhuarc30's Avatar
I never heard of it, but that means nothing. It looks to be nothing more than an improved base plate (maybe). The guys story sounds kinda fishy. Besides the price is up to 350 now, just pick yourself up an edelbrock piece for that price. BTW the 30-40 hp claim for just a base plate is totally bogus.
John
Old Mar 13, 2002 | 12:07 PM
Little GTA's Avatar
The distributor clamp down bolt hole placement is the same as my Accel intake...which is different than my stock intake.
The "A" he talks about could be a ground off "Accel" name
Old Mar 13, 2002 | 12:10 PM
Jim85IROC's Avatar
Actually, I've decided on an accel base. I never had any intentions of buying this one on ebay. It's just that I've never in my life heard of such a "rare" factory baseplate, and found it to be very fishy. I just wanted to share and see if somebody knew something I didn't.
Old Mar 13, 2002 | 12:19 PM
johndo1707's Avatar
it sure is a beast if its the one off the firehawk. that is the ultimate fbody!
Old Mar 14, 2002 | 02:46 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
A friend of mine has the T-Ram from SLP and the base looks nothing like the stock TPI base.
this is my buddy's motor,
Oh, I just noticed that the Red Firehawk has the same Cold Air setup I have.
Old Mar 14, 2002 | 02:53 AM
Sauron91's Avatar
Look at his other auctions.
He sells NASCAR heads and the infamous "Ultimate Racer's Table," which is made of a V6 block from blahblah, it's rare too
Old Mar 14, 2002 | 06:53 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I don't believe it. Why? The intake looks exactly like an aftermarket intake with the dual EGR ports (corvette or F-Body), Corvette fuel rail hold downs, etc. So, IMHO, that leaves two possible answers ...
1) Its not real.
2) It is real and Edelbrock/TPIS copied this design for their aftermarket base.
Tim
Old Mar 14, 2002 | 11:59 AM
CarnageGTA's Avatar
How does the (T-RAM) setup work? DId yur buddy notice any big difference besides the good looks? SLP hun? Gonna check them out just for fun
Old Mar 14, 2002 | 01:11 PM
u r sofa king we tah did's Avatar
good looks? looks like a big box sitting on top of a motor to me
Old Mar 14, 2002 | 01:59 PM
Zepher's Avatar
He noticed a huge difference. Pulls hard all the way to 6 grand.
He has a 90 Firebird Formula with the L98.
He's had the T-Ram for about 6 years or so. Bought it from Summit when SLP still sold it.
Old Mar 14, 2002 | 05:47 PM
Steve87Pont's Avatar
Zepher,
You need to give him your dual air to make it look complete.
Do you know the part number for the upper radiator hose. I need to use one temporarily until I install mine.
Old Mar 14, 2002 | 05:54 PM
wataru's Avatar
Hey Zepher. Do you know how much he paid for it back then?
Later Barrett
Old Mar 14, 2002 | 08:04 PM
It was sold in 2 parts. I can only find the 1 receipt from Summit.
Sum-SLP20100 T-Ram Manifold 514.00
I believe the other half was around $350
The fuel line kit SUM-SLP 20130 was 149.69
and there was a kit also for the Automatic Trans bracket
Old Mar 15, 2002 | 01:11 AM
Zepher's Avatar
He paid around $1300 or so for everything. That is his estimate since it was awhile back.
I am not sure about the part number for the radiator hose.
I don't even think I needed to put the SLP one on, I just put it on since it came in the kit. With the stock hose, it looked like it might have crimped the hose where it goes under the air intake, but the SLP one looks a little crimped as well.
Also, it is a pain to remove the drivers side Valve cover with that hose there.
My Dual will be for sale when I put my Turbos on.
Old Mar 15, 2002 | 05:34 PM
wataru's Avatar
WOW! $1300 bucks for that thing 6 years ago. Pricey peice of hardware. Thanks for the info.
Later Barrett
Old Mar 15, 2002 | 06:55 PM
rezinn's Avatar
I should put my stock intake manifold on ebay and say it's rare and set the reserve at $250. What a joke.
Old Mar 15, 2002 | 06:58 PM
rezinn's Avatar
Oh my ***. Look at the coffee table he's selling, it looks like someone dropped some heads on a chair and glued a piece of glass to the top. What a piece of junk.
Old Mar 16, 2002 | 09:50 PM
dlp's Avatar
dlp
A T-ram with all the necessary brackets and adapters retailed for about $ 1,450.00 from Summit.
Basically the T-ram is a tunnel ram base with a large box/plenum on top.
I believe the in-take runner length is 11 inches which falls between the LT-1 in-take and stock TPI runner length.
I bought my T-ram in 1995 and at the time there were three different manifolds available. TPIS Mini Ram, Super Ram & T-ram. The reason I chose the T-ram was it is emissions legal and was supposed to allow higher RPMs than the Super Ram.
Old Mar 16, 2002 | 10:48 PM
Jim85IROC's Avatar
I think it's damned cool.
armybyrd
Sep 28, 2023 12:16 AM
Lbibb
May 5, 2016 12:00 AM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
okfoz
Oct 13, 2015 02:19 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
