afpr, code 36, idle surging
Old Mar 14, 2002 | 11:50 AM
ducmon900's Avatar
I'm having a idle surging problem right now and I'm sure its related to my code 36. The motor ran good with no idle surging or code 36 until recently when i ported the heads and intake. Since then I've been getting a surging problem. I've checked the relay which is okay, tps is set at .571 (this is strange, last fall i set it at .54), ecm is fine, fuel pressure set at 50lbs. I've been setting a code 36 lately too. Today I cleared the code, started it up, idle was spiking and as it dropped it set a code 36. Anyhow one thing I have noticed is it spikes until warm until I do one thing and that is unhook the vacuum at the plenum for the afpr. Then it idles fine. What gives?
Tomorrow I'm going to set the tps and iac. Trying to get it to run right before I start burning chips for it.
Old Mar 14, 2002 | 10:08 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I would first get rid of the code, 36 is MAF burnoff relay so I would start by changing that. If the surging idle happened after the porting I would suspect a vacuum leak somewhere.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
355tpipickup
Sep 4, 2015 05:32 PM
