problem help quick
Old Mar 17, 2002 | 10:48 AM
BLUEIROC5.7's Avatar
problem help quick
Hey all i have a 89 iroc 350. The problem is with the ignition. The key turns all the way to the start position and then it is stuck. When i turn the key all the lights come on but after that part it won't move . I dont know what to do
Old Mar 17, 2002 | 06:50 PM
Hey all i have talked to my friends and they say it the key cylinder. Is this wright or what is it
Old Mar 17, 2002 | 06:56 PM
topdown's Avatar
If it's a physical movement problem it's usually the ign lock cylinder, but if it doesn't function properly in it's normal positions it's more likely the ignition switch(on the lower steering column).
Infested
May 22, 2018 11:56 PM
mike_c
Aug 27, 2015 04:32 PM
TheJoeY88
Aug 13, 2015 06:51 PM
