Anyone ever switch the stock 350 tpi intake for a miniram & was it a big perf. gain?
Old Mar 18, 2002 | 08:06 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Anyone ever switch from a stock tpi to a miniram & notice a BIG diference in performance? 1\4 Times with before & after results if u have them would be appreciated. Mostly stock 350 tpi motors cam, headers, free mods, & chips. No Heads, Super high duration cams Etc.
Do u think that buying this intake is a better idea than buying the heads first? It seems to me that buying the High flow lower intake, High flow runners & porting the stock plenum just doesnt make any since for the price!
thanx in advance
Old Mar 20, 2002 | 08:12 AM
86Tra/maro's Avatar
I guess this has never been done before.
Old Mar 20, 2002 | 10:13 AM
Beefy89's Avatar
I've wondered the same thing about the Vortec manifold from SDPC.Seems some people have them,but I've never seen any real performance numbers on that manifold.
Maybe I was sick that day.
Old Mar 20, 2002 | 11:08 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i think someone already has done this swap but hasn't posted or i was asleep. i would assume minimal gains from just the intake swap alone. being that the l98 cam was not designed for optimal performance in the rpm range that the miniram shows good gains in. swapping the intake and a nice cam will help. then again there are the heads that become the restriction.
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
putting a Miniram on a relatively stock L98 is pointless. the miniram puts the power band higher up in the RPMS. If the heads and cam can't support or maker power at higher RPMs then its all for nothing. I'd do a nice set of heads,maybe find an aftermarket base cheap, port the plenum and get runners, or hog out the stock ones.
Old Mar 20, 2002 | 11:09 AM
Car: 1988 IROC-Z
agreed
1992rs/ss
Jan 31, 2025 05:10 PM
camaro71633
Sep 1, 2015 10:24 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
